584,879 active members*
5,367 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > My table moves the wrong way when using jog arrows?!!!
    Jul 2008
    139
    When I press the tab button to get the jog windown up & then use the shuttle arrows - if I press the top green Y+ ...I'd have expected the table to move away from me, when I press the right pointing X+, I'd have expected the table to move to the right - are these correct assumptions? (becuase at the minute my table does the exact opposite to the above - if it shouldn't act in this manner...how do i resolve this please?!!!)
    Apr 2009
    108
    table vs. tool movement
    keep in mind that the + and - buttons are used to position the tool on the part. If you want the tool to move in a + direction the table will move in a minus direction. This assumes you are using a vertical machine.
    If, for some reason, the tables are now moving in the opposite direction that they used to check that mirror image has not been set on by accident.
    Jul 2008
    139
    Thank you for your response...that was indeed my issue.
    that said, i have a real whacky transport problem now.
    My Y table is now fine ...in other words, I press either a Y+ or Y- & the table moves just fine in either direction.
    However my X axis...no matter whether I press the X+ or X- ...my motor turns the same way. (the table only goes one way).
    I thought perhaps a wiring fault. Therefore, I moved the Y axis motor (which is the same motor type/wiring & working fine) & connected it to my driver board's X motor output - same thing (X only only moves in one direction, no matter whether X+ or X- is pressed!)
    Since I've ruled out the motor & wiring, this can only mean it's either the board (X axis screwed?), or some setting in Mach3??
    ....HELP!!!
    Check the voltage on the direction pin, while jogging in both directions. Should be 5V one way, and 0V the other.
  1. y home moves over
    By japco43 in forum DNC Problems and Solutions
    Last Post: 03-11-2009, 12:34 PM
  2. Someone correct me if I am wrong about my new router table
    By CncForMe in forum DIY CNC Router Table Machines
    Last Post: 12-23-2008, 02:25 AM
  3. Getting some bad moves.
    By Stampede in forum BobCad-Cam
    Last Post: 09-27-2008, 01:47 AM
  4. Can't use keypad arrows
    By bcnc in forum Mach Mill
    Last Post: 10-25-2007, 01:28 AM
  5. wrong approach with xy-table?
    By sweFredrik in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 02:59 PM
