Help! ...no drive movement
I wasn't sure which forum to post this in ....anyway...I have no drive movement at all.
I'm using a asus 2.4 running xp connected to Bob Cambells breakout board and it's driving Gecko 201's.
I went through the mach 2 manual and set all my I/O's. I've checked the pin assignment with the doc's that came with the breakout board and there all the same.
All my limits and my home proxs work good.
When I ref. a drive, Mach 2 is showing movement on the DRO but I have 0vdc on the phase output of the drive. The drive has 48vdc at the power terminals and the red leds on the drive are lit.
I checked the dir and step pins coming from the breakout board while it is idle, and i get 4.2 vdc on both pins to the common pin (common being +). I disconnected the disable line to make sure my drive disable circuit wasn't faulty.
I get nothing, Is there anyone that can give me some pointers on what else to check? I'm about ready to scrap this project.
Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
