585,883 active members*
4,650 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > DynaTorch > Hypertherm Consumables / Jim Colt
    Oct 2005
    378
    Hi Jim, Before I ask my questions I would like to say I think its great that Hypertherm has an experienced rep to answer end user questions on the internet. In the current state of economics in the US and American icons like GM & Chysler falling, I want to support US companies not just because they are US but because some of them truly offer a superior product AND support.
    In my experience when I have had issues with my cutting and welding equipment and called for help, Miller welding and Hypertherm went the extra mile to solve my problem. I think both of these companies have excellent products. I cringe at the thought of only having the option of buying a Chinese piece of equipment.
    My question, I have a Hypertherm 1250 with the T80M torch for use with my Dynatorch. I purchased the 1250 about 3 years ago. At the time the user manual only listed cutting charts for 80 amp shielded, 40 amp shielded, and 40 amp unshielded consumables. After reading your reply and looking at the picture you posted for the thread "Just got a new 5 x 10 table" I decided to go to the Hypertherm site and down load the newest user manual for the 1250 series.
    In the new manual Hypertherm has added cut charts for 60 amp shielded and Fine Cut consumables. Both manuals leave still leave out the 60 amp UNshielded consumables. This makes for some confusion. I normally use Fine Cut consumables to cut thin aluminum with alot of experimenting.
    Why is there no cutting chart for aluminum with the Fine Cut consumables? Also, I have never used the 40 or 60 amp UNshielded consumables but since they are listed in the manuals I am curious under what material /cutting conditions would they serve better than the shielded consumables?
    Those plasma cuts in your picture look very nice. What kind of torch and shield is mounted on your Plasma Cam in the picture? It looks different than the T80M that I have. Thanks Jim
    Jan 2008
    2247
    The 60 Amp unshielded parts are rarely used....they have a very few applications for robotic or 3 dimensional jobs where the ability to get the torch in real tight spots is more important than cut quality or consumable life. These unshielded parts simply do not perform as well for the majority of cutting applications. In regards to aluminum cutting with Fine Cut parts.....I don't have a good answer for you! I use FineCut parts for aluminum....I suspect that our process engineers had specifications to improve stainless and carbon steel thin sheet cut quality....and they never tested these parts on aluminum. I'll check it out and see if we are working on anything here!
    I have the newest Powermax 45 on my PlasmaCam....totally new torch design.....it is the sweetest cutting air plasma I have ever used.
    Best regards,
    Jim
    Nov 2013
    33
    Smile Re: Hypertherm Consumables / Jim Colt
    Thank you for Jim Colt 's kind help.
    AngelBlade air plasma cutter
    www.abplasma.com
  1. Discount for Hypertherm Consumables
    By rescueweasel in forum Hypertherm Plasma
    Last Post: 07-28-2013, 06:25 PM
  2. Hypertherm 600 consumables
    By makeitlabs in forum Hypertherm Plasma
    Last Post: 09-10-2012, 06:14 PM
  3. Hypertherm Finecut Consumables
    By none in forum Hypertherm Plasma
    Last Post: 04-02-2012, 03:46 PM
  4. Used Hypertherm consumables needed.
    By AccuFast2D in forum Waterjet General Topics
    Last Post: 10-01-2009, 01:47 AM
  5. hypertherm consumables
    By Pure-Powder in forum Waterjet General Topics
    Last Post: 06-04-2008, 04:26 AM
