585,917 active members*
3,488 visitors online*
Thread: Gang tooling
    Feb 2009
    20
    Gang tooling
    How to use a lathe gang fixture with turbo cnc? how about tool offset? when tools are changed are the axis zeroed?
    What is the easiest way to use it without special cam software?
    my setup: turbocnc and http://www.cnczone.com/forums/showthread.php?t=73679
    thank you.
    Sep 2006
    607
    TCNC has its own tool library. You can set offsets on all axis if you want. So gang tooling is no problem as far as I can see. When you change tools it compansates for the length and position of the tool.
  1. School TL-1 and gang tooling
    By TEntpeg in forum Haas Lathes
    Last Post: 12-13-2009, 10:04 PM
  2. Gang tooling vs turret
    By baldysm in forum Uncategorised MetalWorking Machines
    Last Post: 12-03-2007, 11:47 PM
  3. Gang tooling vs turret
    By baldysm in forum CNC Tooling
    Last Post: 11-29-2007, 06:03 AM
  4. Tool Shift for gang tooling
    By elaganis in forum Haas Mills
    Last Post: 03-09-2007, 10:48 PM
  5. gang milling
    By Thoob in forum MetalWork Discussion
    Last Post: 09-05-2005, 02:40 AM
