If you're using the default post for the boss off the CD, it should put the G81's in. That's pretty standard, and any machine that uses G81 as the default drill cycle should have it in the post. Is it possible that the post you're using was modified before you started using it?
Either way, both look like an easy fix, but we'll need to know more.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
