585,977 active members*
4,688 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > CICINNATTI MILACRON - ACRAMATIC 2100 ALARM-APC RACK 0
    Jan 2007
    118
    FRINDS,
    WE ARE NEW TO THIS MACHINE. WE COULD ABLE TO SWITCH ON THE CONTROLLER,DO REFERENCING EVERYTHING FINE.
    BUT FREQUENTLY WE ARE GETTING THE ALARM APC CHECK RACK-0 FOR OVERLOAD.BUT IN THE MACHINE THERE ARE RACKS FROM 1-6.
    WE DO NOT HAVE THE ELECTRIAL DRG.
    HOW TO PROCEED.
    TAHNKS ,
    CHANDRU
    Apr 2006
    37
    Not knowing the machine, the APC functions are controlled by a "smart brick", an I/O device. It is probably located in an electrical box about 12" x 12" x 4". All the solinoid cables, switch cables etc. will be plugged into it. I have seen problems with vibration loosening connections. I have also seen heat being a problem. If all connections are good you will probably need to replace the unit.
    May 2007
    64
    Check all connections and reseat the boards in the rack, this is a common problem with the 2100 controller, reseating the boards fixes lots of things.
    Rick
    Jan 2009
    Check your 24 volt power supply. We had same problem blown fuse on supply.
    Mike
    Feb 2009
    11
    Re: CICINNATTI MILACRON - ACRAMATIC 2100 ALARM-APC RACK 0
    Have you found the issue, this post is a bit dated.
    Very familiar with the APC Rack setup and Smart Brick application.
  1. Acramatic 2100 Alarm 44-84
    By viel in forum Cincinnati CNC
    Last Post: 09-06-2021, 08:18 PM
  2. Replies: 6
    Last Post: 01-02-2014, 08:13 AM
  3. Replies: 1
    Last Post: 07-15-2013, 10:45 PM
  4. Cincinnati Milacron Acramatic 2100 Power Supply Failure error
    By Wurmwood in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-17-2012, 07:53 PM
  5. Replies: 3
    Last Post: 09-05-2011, 01:19 PM
