585,978 active members*
4,250 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Biesse Rover 321R CNI Compact XNC
Page 2 of 2 12
Results 21 to 34 of 34
  1. #21
    Ha
    Hardly a wiz but i have the gcode down enough to program most things. I hope he gets back with a translation but posting in english even bad english would be better.
    Measure twice, cut once and if it ain't broke, don't fix it.
    There are 3 types of peaple in this world, those that can count and those that can't.
  2. #22
    Feb 2008
    482
    glad to hear that. pm me if you ever get stuck with something you cant work out. ive had mine for 2 years now so i ve learnt how to break things cnc style! have a look at my other recent posts, some good examples of parametric which may help you if your doing repeat work in differing sizes etc
    so much to learn, so much to pass on.
  3. #23
    Nov 2010
    Does anybody know about info on 9spindle drillbanks
  4. #24
    No
    Sorry, not me.
  5. #25
    Oct 2016
    5
    Beisse
    Hello!!! I'm from Argentina. I'm writting to get some help for a friend who has a Biesse Rover 321R (1997)
    The thing is that he is writting every program directly through the machine.........:idea: yes..... he is f*****king crazy, he uses the machine funtions to do everyting, so since i'm building my own hobby cnc, and have allready learned about VCarve and DXF, told him "you're prehistoric!!!" but the thing is i have no idea how to send the G-code from VCarve or 3Dcut to the machine
    It has a diskette, but he has told me that you have to format it in some way that's make it really complicated.
    Please!!! help me to help
    Thanks!!
    Mariano
  6. #26
    Feb 2008
    482
    Re: Beisse
    you cant.
    the biesse 321 control is prehistoric.
    no way to drip feed.
    you can raw write a diskette- but only max 11k (about 300 lines of code)
    the only post processor i know of is the one i wrote for sheetcam.
    ive replaced the controls in my biesses now!
  7. #27
    Oct 2016
    5
    Re: Beisse
    hooooooo no luck, thanks for you quick reply.
    So, what should i do???
  8. #28
    Feb 2008
    482
    Re: Beisse
    Quote Originally Posted by Coroao View Post
    learn how to retrofit a very old complex machine- like i did! - lots of work- lots of programming!
  9. #29
    Oct 2016
    5
    Quote Originally Posted by battwell View Post
    But vcarve saves in a "blessed Rover arcs" code.
    Could I just save it on a floppy disk and run it on the machine?
  10. #30
    Nov 2005
    172
    Re: Biesse Rover 321R CNI Compact XNC
    If the control has the network card, you can network it but it would only be to a much older system (think Windows 98)
    The reason most people program the manner which you stated is, for panel processing, the parametric control capabilities were
    very powerful and in most instances people did not need a CAM option.
  11. #31
    Mar 2017
    Quote Originally Posted by MarkT View Post
    As it has FTP capability, it is accessible to any computer. I was able to get my 1997 Biesse Rover 322 talking on the network last night, and am now able to FTP from my Windows 10 laptop to the filesystem,
  12. #32
    Oct 2009
    16
    Re: Beisse
    hi battwell is ther way to retrofid this machine with new controler, as you have done for your machine?
    thank u
  13. #33
    Feb 2008
    482
    Re: Beisse
    Quote Originally Posted by sarus View Post
    thank u
    if your machine has ac servos- its quite easy by swapping the drives. (easiest way)
    if dc like mine- id consider new motors/drives
    was very complex the way i did it 9 years ago. but the machine is still running well.
  14. #34
    Oct 2009
    16
    Re: Beisse
    my machine own AC servo ,
    so how to do that?
    thank u
Page 2 of 2 12
  1. Biesse , Rover 321R
    By lamicron in forum Biesse
    Last Post: 05-27-2013, 01:42 AM
  2. Biesse Rover 321r Hard Drive Space
    By floydwrodgers in forum CNC Machining Centers
    Last Post: 11-27-2012, 02:42 AM
  3. Controller for Biesse Rover 321R
    By grc in forum Commercial CNC Wood Routers
    Last Post: 07-31-2009, 12:11 PM
  4. rover 321r
    By la cuisine in forum OpenSource Software
    Last Post: 07-28-2009, 10:15 PM
  5. Biesse Rover 321R questions
    By bigz1 in forum CNC Machining Centers
    Last Post: 07-18-2009, 01:37 PM
