Hardly a wiz but i have the gcode down enough to program most things. I hope he gets back with a translation but posting in english even bad english would be better.
Measure twice, cut once and if it ain't broke, don't fix it.
There are 3 types of peaple in this world, those that can count and those that can't.
glad to hear that. pm me if you ever get stuck with something you cant work out. ive had mine for 2 years now so i ve learnt how to break things cnc style! have a look at my other recent posts, some good examples of parametric which may help you if your doing repeat work in differing sizes etc
so much to learn, so much to pass on.
Does anybody know about info on 9spindle drillbanks
Sorry, not me.
Hello!!! I'm from Argentina. I'm writting to get some help for a friend who has a Biesse Rover 321R (1997)
The thing is that he is writting every program directly through the machine.........:idea: yes..... he is f*****king crazy, he uses the machine funtions to do everyting, so since i'm building my own hobby cnc, and have allready learned about VCarve and DXF, told him "you're prehistoric!!!" but the thing is i have no idea how to send the G-code from VCarve or 3Dcut to the machine
It has a diskette, but he has told me that you have to format it in some way that's make it really complicated.
Please!!! help me to help
Thanks!!
Mariano
you cant.
the biesse 321 control is prehistoric.
no way to drip feed.
you can raw write a diskette- but only max 11k (about 300 lines of code)
the only post processor i know of is the one i wrote for sheetcam.
ive replaced the controls in my biesses now!
hooooooo no luck, thanks for you quick reply.
So, what should i do???
If the control has the network card, you can network it but it would only be to a much older system (think Windows 98)
The reason most people program the manner which you stated is, for panel processing, the parametric control capabilities were
very powerful and in most instances people did not need a CAM option.
hi battwell is ther way to retrofid this machine with new controler, as you have done for your machine?
thank u
