586,011 active members*
4,215 visitors online*
Results 1 to 10 of 10
    Mar 2008
    9
    Needs help to get .000 position 17 holes
    :drowning:Hey Guys need your help, I have several parts to make but BP shows .000 in position in 17 holes, can somebody tell me how can make those parts?
    parts are from aluminun .100" thick
    Jan 2008
    449
    Go kill the engineer! Is this in a circle or a straight line? How far apart? Cnc or
    manual?
    Feb 2008
    547
    Cool
    Aaaa yes....here is the simplest answer. .000 position allows for the possiblity of bonus i.e no bonus no positional allowance occurs if you make the holes their smallest diameter. Bonus and positional allowance occurs if you make them at to their largest diameter. i.e the diameter is .800 +- .005. At .795 you have no allowance or bonus tolerance. At .805 you have +- .005 or about true position of around .0027 ( an est. I didn't figure it out) Also... there is tol. to the location of the BH center location you can add to that.:banana:
    Steve.
    Mar 2008
    9
    thanks and another tip
    Thanks for your help
    I'm sending part of blue print let me know if we can apply same criteria to make those parts
    Thanks Again
    Attached Files Attached Files
    Mar 2008
    9
    we will use a cncn fadal 4020 10000 rpm 20hp
    May 2006
    132
    listen to scadvice.
    you have .000 at .266 diameter.
    you have .03 at .296 diameter.
    good luck
    billy
    Feb 2008
    547
    Red face
    Quote Originally Posted by scadvice View Post
    Steve.
    Thanks billy....Yes...the same applies. I do want to make one correction though to my original example. I said "or about true position of around .0027 " . That was incorrect. It should have been around .0073 true position. I estimated the wrong way. I was in a hurry to leave and go visit some friends.
    Steve
    Mar 2008
    9
    Thanks a lot for your help.
    I apreciate your support
    Jan 2007
    243
    True position of ".000" What!? Has to be a Typo on the print. Here is a calculator if you need help calculating the actual True Position on your parts: True Position Calculator. Easily calculate the True Position of Holes with or without Maximum Material Condition (MMC) !
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
    Dec 2015
    11
    Re: Needs help to get .000 position 17 holes
    Just hold it close as you can. If you don't have reamers, drill about one size under then follow with the correct size. Walah size is dead on!
  1. Position Page and Relative position
    By tnik in forum Haas Lathes
    Last Post: 11-03-2012, 06:37 PM
  2. Replies: 15
    Last Post: 03-12-2011, 07:53 AM
  3. losing position, lots of position
    By cyclestart in forum LinuxCNC (formerly EMC2)
    Last Post: 01-24-2010, 08:50 AM
  4. Replies: 4
    Last Post: 10-28-2009, 06:39 AM
  5. What is the best way to position holes on a tube.
    By voxelman in forum MetalWork Discussion
    Last Post: 04-15-2007, 06:02 PM
