Hi Everybody
I am writing you because i just bought an old used Amada Coma with the Fanuc 6M and i have a problem with the zero setting when i power on the machine.
Everytime i restart the machine i must make the zero of the Y axis and X Axis.
Now i have no problem with the zero of the X axis everytime the axis run to the home position decelerate and find the zero but with the other one is difficult to find the zero.
In fact the axis run decelerate but the light of the Y zero do not turn green and i have no ossibility to go ahead with the program or work.
I would like to know if somebody found the same problem and what is the cause.
Just to inform you that i have no parameter list, the only that i have is the one i wrote down the first time i made run the machine.
I also changed the deceleration micro position but nothing, sometimes the machine catch the zero inmediatelly and other times i spend long time to find it.
I also checked the brushes and all is fine, i opened also the encoder cap on the motor and cleaned the little brushes that are on it but nothing to do.
I am considering problems with the encoder but if i catch the zero after this i have no problems, maybe sometimes the machine does not return to the zero position but nothing that do not permit me to continue my work.
I was thinking to change the zero position in the parameters but i have no parameter list explanation so i do not know what is the correct parameter i must change.
I do not know if there is a procedure like in the OT to reset the zero positions after the transport of the machine.
If you have any suggestions please email me ir answer me
Will be very preciated.
