585,992 active members*
6,309 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Videos of servos/steppers in action
Page 1 of 2 12
Results 1 to 20 of 24
    Sep 2004
    1207
    This is a thread where everyone is free to post their videos showing machines controlled by VSD drives in action. Here is couple from me:
    This video demostrates VSD-E drives drives controlling a laser diode characterization instrument.
    The video demostrates VSD-E's automatic homing function at power-up. While doing homing motion to left, drive gently detects mechanical stop of axis (no mechanical limit switches are needed). After axis end has been reached, drive continues to opposing direction and searches encoder index pulse for most precise homing.
    The machine has 2 axis, both in same direction and stacked. The upper linear stage has short travel and higher mechanical precision for microscope camera movement. The lower stage (long travel) has a 150W BLDC servo motor and upper stage has a small 10W DC servo.
    [ame="http://www.youtube.com/watch?v=pGnR1M4GH5Q"]YouTube - Servo axis homing with VSD-E drive[/ame]
    This is same machine as above but this video shows some operation and jogging of machine from PC.
    All motion control (accel & decel ramps, velocity control, torque limiting, axis travel limiting) are done internally in VSD drives. PC sends only simple move commands to drives thru USB bus.
    [ame="http://www.youtube.com/watch?v=jrLgFcVvx2U"]YouTube - Servo motor control with VSD-E[/ame]
    Comments & new videos are greatly appreciated
    Mar 2009
    Smile hello
    Quote Originally Posted by Xerxes View Post
    I contact you for your VSD -E drive
    I make a mail in this week to ask you informations before buy it
    I think it's great drives :-)
    I want to install a Smooth Stepper
    I contact you on the week because it's not easy for me to write in english, I need a little time :-)
    I have a workshop in FRANCE, i make parts bikes with CNC Mill but I want to use servo motors for speed
    Regards
    François CHARLOT
    my mail : [email protected]
    Nice Idea, I tried a Youtube search a couple of weeks ago while I was researching your drives, it nice to see them working.
    Sep 2004
    1207
    Here is another one. This is a video showing fast 3D CNC milling. The servo drives used in this machine are our older drive models (VSD-A's).
    The video has been recorded by one of our customers and has been published with his permission.
    [ame="http://www.youtube.com/watch?v=fHdyy9ylLNE"]YouTube - CNC mill with VSD-A drives[/ame]
    Sorry please delete this post wrong topic.
    Sep 2004
    1207
    Here is a new one. It shows a linear servo motor in action:
    [ame="http://www.youtube.com/watch?v=BhcZBr38Kmc"]YouTube - Linear servo motor[/ame]
    Aug 2007
    558
    Here's a short clip of the first cut with this machine, running VSD-XE drives (80Vdc version).
    [ame="http://www.youtube.com/watch?v=Isg5vljnYug"]YouTube- First cut.AVI[/ame]
    Sorry it's not more exciting. The cutter is definitely not for plastics, being 4 flute and coated - but does an ok job except for the very tip leaving a bit of a mess... I'll work on something better
    Best regards,
    Jason
    Jun 2005
    476
    Nice videos!
    That linear servo is amazing! It'll probably be another 10 years before we can take our pick of linear servos on ebay (from decommissioned equipment). Unless new prices drop dramatically...
    Jason, is your machine purpose-built for PCB routing? It looks great! Nice idea to use such huge linear rails, eliminating the need for pairs of rails and all the associated alignment!
    Sep 2004
    1207
    Very nice Jason!
    Linear servo might be practical to hobbyists as linear motor is probably the easiest motor to build as DIY. It is just made out of standard magnets, iron and coil. I have built one my self and it worked.
    The hardest parts are the design (there are hobbyists that have done FEM simulations and designed RC motors) and making really tight winding of coils to maximize available force.
    Or maybe one could just buy the "forcer" (coils) part from some manufacturer and make magnet track as DIY to save some amount of cash.
    Aug 2007
    558
    Quote Originally Posted by damae View Post
    Hi Damae, my apologies for not replying sooner! The machine wasn't built with any particular purpose in mind, the goal was high accuracy and repeatability for small parts machining. I'm very happy with it
    Xerxes, thank you for your kind words!
    Best regards,
    Jason
    Aug 2007
    558
    Smile Another video!
    Here's a slightly better video of our VSD-XE powered mill. Cutting acrylic again, this time with a much more appropriate cutter!
    [ame="http://www.youtube.com/watch?v=92SRZ4kmIQU"]YouTube- Vacuum table test[/ame]
    Feedrate is 160 ipm, 1/8" single flute cutter, DOC 1/8" at 20,000 rpm.
    The pulse smoothing feature in GDTool is giving us really nice smooth curves and a great finish - the edges of the shape in the third photo are quite transparent.
    Best regards,
    Jason
    Attached Thumbnails Attached Thumbnails IMG_5669 2.JPG   IMG_5685 2.JPG   IMG_5683 2.JPG
    Sep 2004
    1207
    Thanks for the video, very cool! Your machine really seems to cut shiny edges :-)
    I assume you also used brushless servos on this mill.
    Aug 2007
    558
    Thank you! Shiny edges are very important
    Yes, brushless servos all round again, I'm very pleased with them. I was also struck by how quiet they are, despite being tuned very 'stiff'.
    Best regards,
    Jason
    Aug 2007
    558
    Smile Another video
    Here's another machine running Granite Devices drives, this time VSD-E 160Vdc model. Also using the new SPS-600-126 power supply as well, with 225 watt brushless servos.
    Still some work to do commissioning this machine, but so far I like it very much!
    [nomedia="http://www.youtube.com/watch?v=4cdVuW1rVtU"]YouTube- DeskMC-panel.m4v[/nomedia]
    Best regards,
    Jason
    Ps - wonder why the video isn't embedded this time?
    The fan grill on that part is pretty cool. Nice video.
    Apr 2006
    3498
    Very Nice drives... What are the prices?.. Amazed to see the 3D carving at that speed.
    Regards
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Aug 2007
    558
    Hi Khalid,
    The VSD-E is €199 (about US$255), VSD-XE is €243 (about US$312).
    Best regards,
    Jason
    Apr 2004
    52
    Cutting Aluminum Dry
    Hello Jason,
    I watched your video and was surprised to see that you are cutting the aluminum dry. What type of bit were you using? I have trouble with the aluminum building up on the bit unless I use some type of lubricant. WD40 works well for me but tends to make a mess. Would you mind sharing your secrets.
    Very nice machine.
    Larry
    Aug 2007
    558
    Hi Larry,
    I was cutting dry, yes. It was more a matter of getting away with it by using a very light cut than anything else. It was a conservative start for the machine, I wanted the part to work first time but really feel this mill could do a lot better. It was a 1/4" 3 flute, high helix cutter, feed rate was 80 ipm and rpm was 20,000. That will probably wear the tool prematurely. The part was a bit warm afterward, so the chip load was too small - tool tables tell me I should have the feed rate at 385 ipm and 32,000 rpm. I'll give that a try and see how it goes, my guess is the tool will clog and break without coolant.
    Regards,
    Jason
    Aug 2007
    558
    Oh, and Gerry - thank you for the kind words. I'm still using your Mach3 screen and really liking it. Thanks again for sharing it after all the work you put into it!
    Regards,
    Jason
Page 1 of 2 12
  1. Servos vs Steppers?
    By ZenOrbit in forum Canadian Club House
    Last Post: 02-06-2008, 02:20 AM
  2. Steppers vs Servos
    By Mits in forum Spanish
    Last Post: 03-03-2007, 03:26 AM
  3. All in one steppers and servos.
    By J Solinger in forum LinuxCNC (formerly EMC2)
    Last Post: 09-29-2006, 07:42 AM
  4. Servos or steppers
    By Paul in OK in forum Commercial CNC Wood Routers
    Last Post: 11-17-2005, 10:11 AM
  5. steppers vs. servos
    By twombo in forum DNC Problems and Solutions
    Last Post: 06-10-2003, 08:43 PM
