585,978 active members*
4,539 visitors online*
Results 1 to 14 of 14
    Apr 2008
    136
    Need Breakout Board Schematic
    Hi guys,
    I'm on the way to build new mini lathe machine for simulation using mach3.
    I'd like to make breakout board DIY. But I can't find the schematic/layout design.
    Does anyone can help me to build the breakout board?
    Dec 2003
    24221
    What do you mean exactly 'for simulation' if this for testing and not actual hooking up to a machine, then you do not really need isolation and the I/O power could come from the PC 5v & 12v.
    For simulating outputs a 2n7000 switch a 12vdc relay or LED would work, the 5v inputs would switch directly.
    If you need an actual isolated output board then you could buffer some opto's from the P.P. output with 2n7000's or more compact, ULN2003 Darlington array.
    Al.
    Albert E.
    Apr 2008
    136
    sorry for misexplanation..
    before I hook up to the machine, I'd like to test it first with all driver connected
    of course I need actual isolated to protect my PC's.
    Any idea Al? I've read on PMinMO look interesting
    Dec 2003
    24221
    Also a you using Vero or other perf board, or actually etching a PCB?
    If using Perf board then you could hardwire in the 25pin cable, if you download the sheets for the ULN2003 and 4n35 opto, it is a simple matter to connect them.
    The input side of your opto could be taken off the 12v PC supply.
    Often the opto output can go direct to your drives etc.
    There is no need to make it too complicated.
    Al.
    Albert E.
    Apr 2008
    136
    Now I'm using perf board for a while.If I found a great source for schematic maybe I planning to etching a PCB later.
    Okay Al, I try to connect this "messy" wire first
    Jan 2009
    334
    BoB schematic
    Quote Originally Posted by parametric.ms View Post
    Try the link below, complete schematics. I am currently using it with Mach 2 & 3 and EMC2 for testing of a servo system. I plan on refining it, moving all components to top side, plus adding relays. The Bob is in the upper left.
    http://members.shaw.ca/swstuff/bob.html
    Hope this helps,
    Iron-Man
    Apr 2008
    136
    Quote Originally Posted by Iron-Man View Post
    Hope this helps,
    Iron-Man
    great reply Iron-Man...
    this is what I lookin for.... May I discuss with you privately later?
    Feb 2009
    1290
    Thanks for this project, I will be routing a board ASAP!
    Jan 2009
    334
    Yes
    Iron-Man
    Feb 2009
    1290
    I'm almost finished building the BOB Iron-man posted from parts in the bin. However I cannot find a 2N2222 tansistor. What would be a good compatible replacement?
    Apr 2010
    486
    Quote Originally Posted by Drools View Post
    2N2222 is probably the most common utility transistor ever built. Any electronics house can help you find similar transistors.
    Tom
    May 2007
    250
    Question
    Iron-man,
    I am little puzzled.
    Does it have charge pump system on this schematic or not?
    Mongkol
    Oct 2008
    406
    Try DigiKey: http://search.digikey.com/scripts/Dk...2n2222&x=0&y=0
    Bob
    "Bad decisions make good stories."
    Jan 2009
    334
    Quote Originally Posted by Mongkol View Post
    Iron-man,
    Mongkol
    Go to this link http://members.shaw.ca/swstuff/bob.html
    It uses a pulse driven watchdog interface, it is an option. http://www.datasheetcatalog.org/data...01-MAX6304.pdf
    Did you see the question and answer section?
    Hope this helps,
    Iron-Man
  1. Sieg C2 motor control board schematic?
    By HankMcSpank in forum Mini Lathe
    Last Post: 09-09-2009, 09:13 AM
  2. Boss 4 RCK board Schematic
    By jodybo in forum Bridgeport / Hardinge Mills
    Last Post: 03-26-2008, 11:42 PM
  3. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
  4. Breakout board
    By joecnc2006 in forum CNC Machine Related Electronics
    Last Post: 06-29-2006, 03:33 PM
  5. breakout board schematic
    By giorgiocnc in forum CNC Machine Related Electronics
    Last Post: 11-13-2005, 05:02 PM
