584,829 active members*
4,690 visitors online*
Results 1 to 12 of 12
    44
    fadal format 1
    does anyone know where i can download a post for mastercam fadal format 1
    i have searched everywhere any help would be apreciated
    Nov 2003
    459
    bthomps5,
    Why would you want to use format 1 on your fadal?
    Sincerely,
    Scott_bob
    Aug 2003
    812
    Every piece of software uses a different post processor, far as I know you can not interchange them (take a mastercam post and use it to post process a bob cad file). So you need to specify what CAD / CAM software you are using.
    Jan 2004
    3154
    Sorry Dude
    I dont use MasterCam and I always use format 2.
    If you want to switch to VisualMill I can send you my custom posts.
    www.integratedmechanical.ca
    Aug 2003
    812
    The MC post for Fadal format 1 is called Fadal1 and is on your Mastercam CD, right next to Fadal2 in the post list.
    44
    thanx for the info
    i have searched and explored the prob is the only post on my cd is Fadal2? i have ver 8.1.1
    Nov 2003
    459
    bthomps5,
    IMO, you'd be much better off using format 2 (fanuc like)
    You don't need any of the fadal cycles for pocket milling or what ever, because you have Master CAM right? I think, if you give format 2 a chance, you'll like it much better...
    What are your thoughts on this?
    Scott_bob
    900
    Talking
    Just to keep the record straight, the Fadal pocketing cycles work in either Format 1 or Format 2. The only difference is that in Format 2 a "D" word must be called out to allow the built in CRC operate. In Format 1 the "H" code reads both the tool length and the tool diameter.
    Neal
    May 2004
    18
    Why not use Format 1?
    Jan 2004
    3154
    Format 2 is most similar (or the same as) to other machines. If you ever need to learn a control on a different machine it won't be so different.
    Maybe this is a stupid reason, but I like it.
    As well everybody I know uses format 2 and it makes sharing files and info easy.
    May 2004
    18
    The only real difference in the program is the tapping cycle. Do not think that Format 1 is a special language unlike Fanuc. Fadal made the Fanuc style easier and safer for operators. That is the only difference. Also remember that Fanuc controls are usually on machines with limit switches and Fadal does not have any. The G28 code is generally used with limit switches. Of the codes will still work on the Fadal, there are easier and better commands that can be used.
    156
    Fadal 1 format
    I customized the MasterCAM .PST file Fanuc format to a Fadal 1 format plus other things the other programer wanted.
    I personally prefer the Fadal 1 format. The Haas mill uses a Fanuc format.
    I switch between formats, it makes no difference to me. The Fadal format 1 requires less codeing - typing.
    G54X-.----Y-.----Z1.G43H#D# (I place the D word here for tool comp)
    versus
    E1X-.----Y-.-----Z1.H# (The Fadal format one does not use the D word for tool comp, uses the H word)
    Just simpler.
    Safety - Quality - Production.
  1. DSTV file format?
    By ABC123 in forum Uncategorised CAM Discussion
    Last Post: 06-28-2013, 06:55 AM
  2. Using Fanuc's G28
    By tahlinc in forum Fanuc
    Last Post: 03-05-2008, 03:20 AM
  3. Fadal 3d Digitizing
    By WORKALONE in forum Fadal
    Last Post: 05-05-2004, 12:39 AM
  4. MP32 fadal controller problem
    By nervis1 in forum DNC Problems and Solutions
    Last Post: 02-01-2004, 08:27 PM
  5. Searching Backwards
    By jonbanquer in forum Fadal
    Last Post: 07-29-2003, 12:53 AM
