585,715 active members*
4,648 visitors online*
    25
    Ball screws and angular contact bearings?
    I am looking to buy a NSK ballscrew for my z-axis and it come with the ballnut and bearings (which I assume are angualr contact bearings).
    One thing I have noticed with most ball screws and their bearings is that they have one bearing on one end and two bearings on the other end?
    My question is:
    1) why is this?
    2) which end should be pointing down towards the table (ie. should the two bearings on one end be closer to the table or further away and closer to my z-axis motor), or does it matter?
    779
    The two bearings on one end are the angular contact bearings. The single bearing on the other end is just a standard ball bearing. This design is meant to trap the ball screw at one end by the two bearings to prevent any linear movement. This linear movement contributes to backlash. The other end is held in the radial direction but able to float in the linear direction to take up movement of expansion and contraction when the temperature changes. You don't want to lock the screw (in the linear direction) on both ends.
    Normally the end with the two bearings is the end where you will attach the motor to power the screw. With this said it's most of the time at the top of the Z axis.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Jun 2013
    6
    i am currently working on the z axis of a mv junior. the problem we have is when we turn power of the z axis begins sagging and we loose our zero return. we think this might be due to the angular contact bearings on top are either not tight enough or they are bad. have any of you encountered this issue or have experience with the bearings to say if we might be headed in the right direction?
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 04-05-2024, 08:10 AM
  2. Which Ball Screws to use?
    By Willyb in forum Linear and Rotary Motion
    Last Post: 01-20-2005, 03:49 AM
  3. Thrust Bearings
    By chas in forum DIY CNC Router Table Machines
    Last Post: 08-06-2004, 12:07 AM
