585,981 active members*
4,189 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Spindle speed low after 3phase to single phase conversion
Results 1 to 18 of 18
    May 2009
    8
    I am attempting to covert a 1993 Fadal 3016 with a Baldor Sweodrive 712 series from 3phase to single phase. I have switched transformers (816 - 814). and from the Fadal diagrams for the T-814, I believe I have everything properly wired (as far as the T-814 goes). Everything appears fine when I power up. I am able to jog the axis into position. BUT, when I try to run the spindle i.e. M3S3000, the spindle runs very slow (maybe 30 RPM). Smooth but very slow. I am hoping that as a newbie, I have done something stupid and I am willing to be used as a bad example of not reading everything I should prior to attempting such an endevor. But, I would rather start making chips than try to find the document that explains what I should have done. Please, if you can help me get my machine running I would very much appreciate it.
    dakotalarry
    Feb 2007
    4553
    Post
    Dakotalarry,
    You may need to purchase a single phase input VFD.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2005
    1194
    Quote Originally Posted by jalessi View Post
    Dakotalarry,
    Jeff...
    That is not accurate the sweo drive can be powered by single or three phase.
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Nov 2008
    9
    Depending on the hp of the motor, you need to use a vfd that fits the hp. I use a GPD 315 for my 7hp perske. The problem when you use 240v converted to 3phase, you loose hp. If your spindle is rated for a higher voltage (mine is 480 normal) the rated hp is now 5hp. The vfd does not make true ac. It makes chopped dc in three phases, I clean the chopped dc with an MTE Series Line Load Reactor LC coil before sending to the perske. Then for safety sake, I limit the speed of the motor to 90% of max, so the 300hz frequency becomes 270hz max. which is 18,900rpm instead of 21,000. When I cut acrylic, the edges will cut your fingers if you aren't careful :-) There is nothing like a Perske!
    Feb 2007
    4553
    Post
    Carbidecraters,
    Please post the single phase wiring diagram for the Sweodrive.
    I was guessing the drive may not work with single phase.
    After thinking about this for a few more minutes, I started to wonder if the drive may only be working on one leg.
    Thank You
    Jeff...
    Apr 2005
    1194
    Alot of guessing in this thread but no real answers yet.
    T-814 can be used with either single phase or three phase. Its wiring diagram is noted in all manuals from 1990-1997 and possibly later.
    The above statement doesnt apply to this issue. Sorry if I sound testy I havent slept in 49hrs
    Feb 2008
    547
    If you have not already checked the voltages on each leg you need to do so.
    Check that the voltages that are coming into the transformer on each leg, next check the output voltages to see that they are what they are suppose to be. If it were me i would then check the voltage drop going to the VFD while the spindle is on. A couple of questions: Before you bought the machine did you see it run and was it running on? 3 phase and at what voltage? I agree with 'carbide' (again) it has to be the transforemer wiring or some other thing assoc. with power going to the VFD.... not the VFD.
    Steve
    Apr 2005
    1194
    The machine was running on 3 phase before line voltage of 210 with a 816 transformer. He has the correct 1170-0 board but has not verified input voltage (IIRC). The single phase wiring instructions are very vague in the Fadal manuals and you have to crossreference the 3 phase wiring diagram.
    There is a suggestion in the manual that on SWEO drives that tells you need to wire L2 and L1 of the input to get the fan to run on the SWEO. This in itself is confusing. The Baldor book says L2 and L3 must be tied together and his electrician says "I hope you didnt wire L1 and L2 together". I really think Larry is not working with the sharpest of pencils in North dakota. Logic tells me L1 and L3 are the same voltage to the VFD because as we know in three phase the line voltage would have to remain consistant. The electrician who stopped by told him if he hooked up L2 and L3 he would complete a circuit...rediculous. Something is definately wrong with the wiring.
    May 2009
    8
    Actually I did check the input voltages and currents. I don't recall exactly what the voltages were but they were very unalarming.. If I remember right 240 and 238. The current was about 4.5 amp with the machine running without the spindel on and about 5 amp with the spindle turning.
    May 2009
    8
    I was thinking about what the electrician said about L1 and L2 and occured to me that he probably though I was talking about the L1 and L2 coming out of the fuse box. The two hot legs into the T-814.
    4826
    What does the schematic for the input hookup to the VFD show? Only connections to two inputs? IIRC, some VFD's require one of the single phase hot wires to be split on two inputs to the VFD, which is the same as tying L2 and L3 together. But the schematic should show this.
    What is providing the 0-10v input voltage command signal after this changeover? Is that working properly?
    Apr 2005
    1194
    Larry I think you will have to go through all the wiring on the T-former and also get that L1 and L2 together like the manual suggests and then check again. Something is just a little off and I thought you had hooked L1 and L2 together and got the same issue. Check those numbers on the t-former and check the wires...double check triple check and mark that off the list.
    900
    dakotalarry--
    Either call me at Mag Maintenance Technologies or send me your e-mail or fax number & I will send you the wiring diagram for a T-814 single phase connection.
    Neal
    Feb 2008
    547
    Larry,
    Call Neal... he is your Fadal man at the service department.
    Steve
    Apr 2005
    1194
    Neal came through! Your the man......man!
    Mar 2007
    76
    Question Hookup info
    Does anyone have hookup info for a Sweo drive part# 010-033? I got one that will turn the motor forward but gets a 'current limit' when attempting reverse? Any info will be helpful. I'm trying to bench test it and don't know how to enable the start command.
    Thanks in advance.
    Hotrob1
    900
    The command signal is on pins 4 & 6 of the six pin molex conncetor.
    Neal
    Mar 2007
    76
    Question Start enable
    Neal,
    Thanks for the answer. The drive I have has a J1 (1 - 12) and J2 (1 - 8). Pins 5-6 (J1) is buffer input - and buffer input +. Not sure what they are. I have tried pulling the forward enable Pin 6 (J2) to pin 8 (J2) common. I know it runs forward but again I missing something.
    I'm also using a 0 - 10V speed command input on Pin 10 (J1).
    Thanks in advance.
    Hotrob1
  1. Driver for 3-phase high speed spindle?
    By dar303 in forum CNC Machine Related Electronics
    Last Post: 03-21-2009, 01:04 PM
  2. 30 hp spindle motor on 240 single phase?
    By panaceabea in forum Phase Converters
    Last Post: 09-05-2008, 11:29 PM
  3. Real 3 phase vs 3phase rotary converter?
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 07-24-2008, 05:36 PM
  4. single phase spindle motor
    By Don Lester in forum Bridgeport / Hardinge Mills
    Last Post: 11-16-2007, 03:37 AM
  5. Spindle speed for Sieg conversion
    By rcotteleer in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2006, 07:29 AM
