585,717 active members*
3,831 visitors online*
    Dec 2006
    49
    Omniturn OT Secondary Offsets
    I have an older Omniturn OT on a Hardinge HSL speed lathe. I am trying to learn how to use the secondary offsets and I’m not having much luck. For a test I set up a simple 2 tool program and tested it. When I add D1 to the tool call out line it moves Z+ right past the stops. The table is empty so theoretically it should not change until I enter something into the table.
    (001 OFFSET TEST)
    G90G94F300G73
    T4D1(DRILL)
    G00X0Z1.5
    G95
    G97S3000M03
    Z.1
    I’m not much of a programmer but can normally work my way through these little hang ups but this time I’m stumped.
    Bob J
    Dec 2006
    49
    False alarm
    Figured it out. The manual shows the D word at the tool call out but it actually goes in the move after.
    Thanks anyway.
  1. Please point me in the right direction (Omniturn)
    By Zebu Fellenz in forum Post Processors for MC
    Last Post: 03-02-2009, 05:14 PM
  2. Need more I/O on secondary paralellport
    By corydoras in forum Controller Cards
    Last Post: 01-12-2008, 08:18 PM
  3. adding camsoft control to an omniturn
    By scolee in forum CamSoft Products
    Last Post: 10-21-2007, 02:09 AM
  4. Need Dimensions of Omniturn Tooling Plate
    By lerman in forum Mechanical Calculations/Engineering Design
    Last Post: 03-07-2007, 06:58 PM
