585,733 active members*
4,876 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Drilling brass detail with 0.85mm drill
    May 2009
    Having problem with drilling 51 hole with 0.85mm drill. I tried to drill holes in one go I mean not turning detail, so i can be sure there will be no errors and top and bottom holes will be coaxial. But it is not working since Ive already broken 4 drillbits. Drill is OSG EX Gold drill cutting lenght is 5mm and shaft statrs only after 7mm. Any suggestions.
    PS. there are 150 details to be machined.
    May 2007
    1003
    You might be spot drilling the holes, but that little drill is wobbling all over the place when it goes to drill the other side. SNAP. If you need to run this way, then change to a carbide drill. Slow the feed WAAYY down when starting it into the bottom material.
    I cross drill in 52100 with a 1/16 inch drill and no spot this way. Good luck with that little drill.
  1. Replies: 2
    Last Post: 12-12-2008, 06:37 PM
  2. Drilling polycarbonate on drill press
    By martinw in forum Mechanical Calculations/Engineering Design
    Last Post: 11-09-2007, 03:45 AM
  3. Drilling 27/64 with solid carbide drill
    By bink in forum MetalWork Discussion
    Last Post: 10-25-2007, 03:59 AM
  4. Drilling o1 drill rod
    By Madbob9 in forum MetalWork Discussion
    Last Post: 06-12-2007, 04:24 AM
  5. drilling codes, which software? I want to drill my pcb with my machine.
    By NickLatech in forum DIY CNC Router Table Machines
    Last Post: 03-17-2005, 01:37 AM
