Hello all, long time lurker, first time poster.
I am just getting into the CNC world and have spent a few months just reading here, to get up to speed before asking any real questions. My previous experience in the electronics hobby makes the open source driver boards or particular interest to me, so hence this post to brush up on some home hobbyist PCB techniques.
In the past I have etched boards for projects, but they have been very crude. I only have an ink-jet printer without a really convenient method to get toner copies or printouts of my work. I used to make fairly simple single sided boards, using those rub-ons and a sharpie, and needless to say the quality was 'in the basement' to put it mildly. It works, but icky. I used to use the PCB express free CAD to lay out the work and then print it on some paper and use it as a reference to measure and make my traces from.
Now I'm into making some much higher quality boards that can be made in a home lab type setup. I am thinking of picking up a eBay special laser printer (any suggestions?) for toner transfer and using some fish tank parts I have around to make a vertical, heated bubbler tank for my etchant for the quickest etch times and best quality. Armed with a copy of Eagle CAD and soon a laser printer I should be well on my way, I hope.
My main questions are concerning the 'fit and finish' of homemade boards as the title suggests. What I mean by this is making the boards more commercial in appearance for aesthetics, as well as the added convenience and safety of a insulating solder mask and thru hole via inserts.
A long time ago I saw a webpage, or perhaps in one of my books even, a strip of via-like devices you could use at home. you insert them into oversize holes, and break them off the strip, then solder on both sides before component insertion, if the via is also used for a component lead. This makes 2 layer boards much more practical, especially if IC lead holes are also used as via's for side to side traces. The problem is, I haven't seen or heard of these things in awhile, not found a online retailer that seems to have them. Any leads on these little gems?
The second question is how to obtain some sort of semi translucent material (preferably green, but other colors are exciting too!) to use as the solder mask. Perhaps a lacquer of some sort can be sprayed on with one of those small airbrush guns. Something that looks as close as possible to the commercial stuff, but has some sort of easy application method at home. I had thought that perhaps for a spray on material, a 2nd toner transfer with just the pads could be placed on to mask those areas accurately. Seems the little 'toner dots' would then be fairly easily removed.
I haven't devised a theory for the silk screen, that is the white component outlines, not the silk screen method for copper etching. Of course, one might be able to use the real silk screen method, but I have no idea how that works or what equipment and supplies might be needed, nor if it will produce a good result, compatibility with the solder mask layer, etc. You don't want something that will just flake off when you touch it. Perhaps those familiar with the process of silk screen could enlighten me to the possibility, or not.
Sorry for the long ramble folks, but I'm hoping there is someone like-minded in the electronics hobby community here that can shed some light, pointers, experience, etc. I know many hobbyist types may not even think all these extra steps would be worth the trouble, but what can I say, sometimes I get carried away and can be a pain in the butt! Thanks guys.
