585,981 active members*
4,229 visitors online*
Page 3 of 3 123
Results 41 to 43 of 43
  1. #41
    May 2006
    107
    Re: Andrey's UHU HP
    I checked it out and think all the elements are OK.
    Now I will set the Vref again and will control of it more often.
    How to do so: If any axis is stopped (error) Mach3 stop too?
    Regards,
    Andrey
  2. #42
    Aug 2006
    2758
    Re: Andrey's UHU HP
    The system should be wired so, if there is an axis drive error, Mach3 should go into EMG stop and the drives should get de-energized. It all depends on your EMG stop circuit wiring and how you want drive errors to be treated in your system. Sometimes you should start the program from the beginning after a stop, it depends on which part of the program is was running at the time, most of the time the part being machined gets ruined.
    Regards,
    kreutz
  3. #43
    May 2006
    107
    Re: Andrey's UHU HP
    Quote Originally Posted by jcdammeyer View Post
    Do you still sell your UHU upgrade board?
    is this question for me?
    I do not sell the board ever.
Page 3 of 3 123
