585,982 active members*
4,630 visitors online*
Results 1 to 7 of 7
    Oct 2005
    11
    EZ-Path Lathe
    Today the monitor crapped out, along with smoke & everything. Anyone have ideas where to get replacement parts now. It's a 1999 machine. Thanks
    Jun 2005
    104
    LCD Screen
    I have a 1995 EZ-Path and it had like a 9" monochrome crt in it that went bad and I replaced it with a VGA LCD color screen. I had to make a small aluminum frame adaptor (and I still have the drawings for it) but it was well worth it. I bought it from earthlcd.com and the item was a SK-2000 SuperKit (10.4" 130 Nit Color TFT LCD Kit) and it only ran about $160. If your machine uses a standard VGA connector for its monitor, then this works fine. In fact I liked it so much, I swapped out my old crt monitor on my EZ-Trak also. I still have that monochrome monitor if your interested in it. Like I said, the lathe is a 1995 and the mill was a 1997 and they used the same monitor.
    I am searching the site for a different problem that I am encountering though. This morning when I fired up the machine, I received a "Keyboard error." I disconnected the keyboard cable from the main board and connected a standard keyboard but it does not help so I think the keyboard card is bad and I am trying to figure out how to fix it. If it ain't one thing it's another!
    Mike
    Nov 2004
    3028
    The original CRT ran on 115 VAC.
    Later machines had a CRT that ran on 12 VDC.
    Where did the smoke come from? The CRT cabinet, or the electrical cabinet?
    George
    Oct 2005
    11
    Thanks for the Info
    The smoke came out of the CRT cabinet. Something really fried in there.
    We connected a plain VGA Computer Monitor to it, so we could keep running. Not sure if we'll fix the original CRT or not. We had to do the same thing with our EZ-Trak. Everybody liked the bigger monitor so much we just left it that way. Thanks again for the help.
    Nov 2007
    11
    Quote Originally Posted by md63825 View Post
    Mike
    I had the same problem on our ez-path S lathe. The PS2 to the larger, older keyboard connection was the problem. Replaced that pigtail and all was well. Hope that helps!
    May 2016
    4
    Hola yo tengo el mismo problena que no me llega señal conwcte un monitor externo desde la tarjeta y tampoco me da señal, alguien me podra ayudar se lo agradeceria
    May 2016
    526
    Hola
    son las conexiones iguales
    ¿Hay luces o voltajes en el tablero?
  1. Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
    By Moscow in forum Bridgeport / Romi Lathes
    Last Post: 06-04-2017, 04:37 AM
  2. bridgeport ez path lathe
    By sempe0 in forum Want To Buy...Need help!
    Last Post: 03-11-2010, 06:01 PM
  3. EZ Path Lathe problem
    By Nitrane in forum DNC Problems and Solutions
    Last Post: 11-05-2008, 02:55 AM
  4. Ez-path Lathe
    By harley88 in forum DNC Problems and Solutions
    Last Post: 05-26-2008, 07:55 AM
  5. Romi EZ Path Lathe
    By kenski in forum Uncategorised MetalWorking Machines
    Last Post: 07-22-2006, 03:25 AM
