Trying to make sure I'm not missing anything obvious or if people have any recommendations!
I'm going to be starting with wood, but I'll eventually be doing aluminum and some steel. I'll worry about getting coolant when the times comes.
Of course:
Electronics:
- Safety Charge Pump
- C10 - Bidirectional Breakout Board
- 3x G251
- KL- 5020, Unregulated Power Supply 1000W, 50VDC/20A
- 3x NEMA 23 BIPOLAR STEPPER MOTOR 270 oz-in
- Already have switches for homing and emergency stop
- Already have parallel cables
Collets and Cutting:
- ER 16 COLLET 12 PIECE ENGLISH SET
- Drill Chuck Arbor and 1/8" to 1/2" Jacobs drill chuck
- Drill Set, 115 Piece Screw Machine Length HSS
- Selection of HSS 2-flute endmills and a few 4-flute carbides to try
- Center Drills, Set of 5 (Numbers 1-5)
Measuring:
- Machinist Square Set, PEC
- Edge and Center Finder, Fisher
- Axial Support Holder
- .030" Dial Test Indicator to fit in the above...I hope
- Inspection Kit, 6-Piece
- Electronic Digital Indicator, 0.5" Starrett
- Already have digital calipers
Fixturing:
- 1-2-3 Blocks
- V-blocks
- Thin Parallels, 3" Long 10 Pairs
- Vise, 3" Screwless with Clamping Slots
- Precision Toolmakers Vise 5"
- Clamping kit, 6 mm T-Slot, 36-Piece
- Assorted M5 cap screws + nuts
- T-Slot Nut (6 mm)
Software:
- Mach3
- Already have SolidWorks and other CAD packages at my disposal
Misc:
- Deburring Tool
- Enclosure once I have machine
- Any recommendation for a source for rubber mat to put between the table and the taig?
*Revised: Changed vise, added drill chuck arbor + chuck, and parallel cable
*Revised: Removes measuring kit and dial test indicator, replaced with Starrett digital test indicator, and already have digital calipers.
