585,967 active members*
4,116 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > CRC programing with an old Fanuc 11M controller
Results 1 to 6 of 6
    Feb 2005
    54
    I've been away from CNC machine for about 4 years and the show I work at just got a CNC mill. The problem I am having is that I can't get the cutter radius compensation to initiate. The machine has a Fanuc 11M controller. I'm not sure if I am inputting the radius offset in the correct location. Do I just input it in the same offset pages that I use for tool length compensation?
    EG. using tool 27 I'm using TLO H27 and CRC D77. H27 being -10.000" and D77 being 1.000" for a 2" dia. tool. Our machine has offsets 1 through 99 but Im not sure if there is a separate offset page for diameter offsets. Can anyone help me out?
    24221
    I am not a machine operator but I believe the D offset is picked up by the G41 or G42. or are you already using this?
    What was wrong with the servo's, by the way?
    Al
    Albert E.
    Feb 2005
    54
    I got the CRC figured out. Thanks for replying Al. One of the boards in the back was faulty. We're running the y axis off the A axis board until we can get a new board or this one repaired.
    May 2004
    5
    You should only have to enter the radius value into the offset page (after the R or T). It could be possible that the parameter for tool comp is not turn on. I think it is Parameter 907.6. :cheers:
    May 2004
    5
    Private Message me for a complete list.
    Aug 2016
    Quote Originally Posted by bbailey View Post
    Do u have a list for the fanuc 11m. For tool comp.thanks
  1. help fanuc programing
    By togr in forum Fanuc
    Last Post: 03-09-2013, 11:11 PM
  2. programing G68 on fagor controller
    By dek in forum Fagor Automation
    Last Post: 04-22-2010, 05:13 PM
  3. Fanuc 3T programing help
    By Kevin Taylor in forum Fanuc
    Last Post: 12-03-2008, 01:10 AM
  4. Help programing fanuc 0-m
    By PRIOR666 in forum Fanuc
    Last Post: 05-28-2007, 09:22 PM
  5. Programing help with fanuc 10T
    By adaptaflex in forum Fanuc
    Last Post: 02-16-2007, 03:11 PM
