585,708 active members*
3,828 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCAD V23 on Fadal 4020 CNC88HS question
Results 1 to 7 of 7
    Aug 2008
    132
    I have a part done in Solidworks, opened in BobCAD V23. It ends up being a very long file, so I am successfully using DNC to transfer it to the CNC88HS control... I noticed however that the feed rate is SUPPPERRR SLOOOOWWW...something like F1.436 or close to that... The material is Aluminum... It is a rough cut... It doesn't seem to be using the default value....?? Do I need to calibrate the feeds between the machine and the software? I am using Format 2, and the CNC88 post...
    Thanks!!
    Jan 2004
    3154
    I know nothing about BCC but I CAN tell you for sure that your issue is with BCC or its post processor has nothing to do with the machine or "calibration of transfer"
    www.integratedmechanical.ca
    Jan 2006
    4396
    There should be a way to Over Ride the Default Feeds and Speeds. Have you checked your Help Files?
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Aug 2003
    449
    MBX5,
    What are the feeds that are being output in your code?
    Chances are that the default feeds and speeds are more conservative than you need.
    You can do one of three things,
    1. Edit the Feeds and speeds per operation. This would entail editing each operation. You do not have to re-compute the paths. Once in the operation, go to the tool page(s) and click the Manual button above the speeds and feeds. Then you can edit the feed rates.
    2. Edit the Cutting Conditions. This one is a rather cumbersome method. Before editing these, search the Help Files for Cutting Conditions. You should be able to find the information needed for adjusting them in that topic.
    3. Do a Find and Replace for the slow feedrates.
    Regards
    Dec 2008
    4548
    Try this.
    Before you generate toolpath, go to your material selection and select ANYTHING other than aluminum. Select ok then go back and re-select aluminum. Generate toolpath and post. If you ever change geometry or the toolpath setting, or close the file and re-open it, change the material and accept it, then change it back to the desired material, re-compute the toolpath and post. Your feeds should be appropriate.
    Aug 2008
    132
    I think I found the problem. I had the correct post selected, but had the wrong machine selected in the Mill section....seemed to make a difference....
    Thanks!
    daveallen Guest
    Re: BobCAD V23 on Fadal 4020 CNC88HS question
    For a free trial of The Machinist Black Book email DaVicki-llc@outlook,com and put trial in the subject.
    Speed and Feed calculator for over 3000 materials and handy references for the machinist and programmer.
  1. 4020 Cnc88hs Control won't boot
    By lmg in forum Fadal
    Last Post: 02-27-2013, 09:29 PM
  2. Fadal 3016L CNC88HS Y axis correction
    By Tomeeii in forum Fadal
    Last Post: 11-01-2011, 04:52 PM
  3. fadal 5020A cnc88hs
    By tc26 in forum Fadal
    Last Post: 09-02-2010, 06:25 PM
  4. FADAL 3016L CNC88HS
    By Repz_zeX in forum Fadal
    Last Post: 02-10-2010, 12:44 AM
  5. Replies: 7
    Last Post: 05-26-2009, 01:38 PM
