585,975 active members*
4,866 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Need help with pinout for VDU on heidenhain tnc145 controller
Results 1 to 3 of 3
    Apr 2009
    95
    To all who can help,
    I just purchased a machine with a Heidenhain TNC145 control. The monitor does not function.
    Does anybody know the pinout for this monitor?
    Are there repair documents for this monitor?
    Kind regards
    Jim
    Oct 2008
    116
    I am not familiar with Heidenhain controller, but most OEM operations bought complete monitors as a subassembly. If you examine the monitor carefully, it will probably have a manufacturer and model number on it. You will probably have better luck getting docs on the monitor that way.
    Is it a monochrome or color monitor? Does it have either a 9 pin D connector or a high density 15 pin D connector like PC video systems? About what year (decade?) was it made?
    BobH
    I know this is an old thread, but I was looking for this information myself and like to share it here.
    It's fot the TNC135 but should be the same:
    23,24: +12V
    21,22: Gnd
    18,19: Video
    16,17: Grey/Intensity
    4,5: V-sync
    2,3: H-Sync
    6,7: Signal Gnd
    I have no idea why the signal lines are 2-wire. Could be either signal/shield or differential. That's something to find out.
    Uli
  1. bridgeport 2/heidenhain tnc145
    By Dar in forum Bridgeport / Hardinge Mills
    Last Post: 03-20-2007, 02:05 AM
  2. bridgeport 2/heidenhain tnc145
    Last Post: 03-12-2007, 09:24 PM
  3. Heidenhain TNC145 post
    By zafarsalam in forum Post Processors for MC
    Last Post: 04-10-2006, 02:26 AM
  4. Help Older CNC JR controller pinout for Mach III
    By sandtoysrus in forum Servo Motors / Drives
    Last Post: 03-17-2005, 08:14 PM
