585,722 active members*
4,069 visitors online*
Results 1 to 10 of 10
    Jan 2009
    16
    RF45 clone CNC conversion
    Hi guys, I have just finished making my RF45 clone into a CNC mill.
    I have turned this into my first ever website. Please have a look and tell me what you think, any comments, dead links or questions, please contact me.
    My website email is [email protected]
    Thankyou
    Graeme
    http://www.graetech.com
    Edit/Delete Message
    Jun 2005
    32
    hi
    great site , thank you , i am also curently workng on a rf 45 clone conversion
    Jul 2006
    1062
    I had a "Dejavooooo" moment there....Have you posted this before?
    For anyone else considering cnc of one of these Marris Freimanis has a faq section on Geckodrive which has an interesting read on the criteria used to select stepper/servo drives/motors :cheers:
    Keith
    Oct 2005
    32
    your site does not seem to work ?
    Jul 2008
    922
    great site! do you mind if i ask what you are using for hosting?
    Jul 2006
    741
    Great site. Will be using some of that info soon
    Aug 2009
    18
    I really like your site. I'm picking up a Grizzly version of this machine (G0484) today and I'm sure I'll use all your great info.
    Jun 2003
    232
    Graeme,
    Your site appears to have a lot of great information on it but I am having difficulty viewing it. Specifically, the text overlaps or is covered by pictures. Is there any specific browser I should use or specific settings?
    Thanks!
    Jan 2009
    16
    Hi, Kanton, yes thanks for letting me know. I have to do some more shuffling around. I tried to make some changes to improve site compatability with I.e.8 but when I did that, I have changed the layout unintentionally. I will fix things when I have a little more time. Int exp 8 is rubish and doesn't load correctly. I use moZilla firefox as a browser and it's much better in my experience.
    Wheatie;
    yeah the z axis uses the factory acme thread screw, it 'works' but it's not brilliant. The Gibbs must be really tight to stop the head flopping around sideways, This loads up the nut fairly heavily. Backlash due to mechanical effects was approx 0.13mm when measured with a dial gauge. I have turned on the backlash compensation in Mach, and it is now reduced to approx 0.02mm which is lots better. If you have the cash. I would recommend that you use a ballscrew and timing belt to gear down for the z axis, without question. I was short on cash at that point in my Cnc conversion, but I have plans to upgrade this year after I do my tax return! I hope that all goes well with your conversion. Best regards, Graeme.
    Aug 2009
    18
    I think I'll just plan putting a ballscrew onto the z-axis into the conversion budget.
  1. RF45 Clone CNC Conversion Started
    By Bird_E in forum Benchtop Machines
    Last Post: 05-10-2009, 08:27 PM
  2. RF45 clone with a DC motor
    By hdj80 in forum Charter Oak Automation Support Forum
    Last Post: 05-29-2007, 11:01 AM
  3. X3 or RF45 clone?
    By logjammer in forum Benchtop Machines
    Last Post: 12-14-2006, 03:34 PM
  4. Pics of my RF45 clone cnc conversion with flood coolant
    By CNCPlastic in forum Knee Vertical Mills
    Last Post: 01-26-2005, 09:02 PM
