I have just received BobCad V23 Pro.
Being my first cam project on the system, I need some guidance.
The plan is to use "Z-level Rough" to rough out the cavity, followed by "Equidistant Offset" to clean up the part. The finish needs to be as good as possible. I want to use ball cutters for roughing and finishing. This means that the edges at the bottom of the cavity would be rounded, so to clean that up, I had planned to use a 3mm end mill. The snag is, I cannot figure out how to select the edges to form a profile.
Is there a more efficient way of doing this? It's going to take for ever to cut?
