585,778 active members*
4,227 visitors online*
    Jun 2006
    44
    G96 Not Working How it Should on T32
    Hi guys,
    I have a Mazak SQT 15MS (new to me). Just started using it. The problem is when I programme Eg.
    N1 T0101 M03 G96 S100
    N2 G50 S2000
    The Controller is T32-3 and the spindle speed slows down as the diameter gets smaller and gets faster as the diameter gets bigger. The exact opposite of what it should do. I expect it's a parameter issue. But can't find it yet. On my other Mazak T32-2 it works fine. Any ideas ?
    Another thing is using the driven tooling. Any feed rate I programme it ignores and uses a feed rate from a parameter I think. How can I change this to programme a feed rate and get it to use it ? I know I have to use G97 for the driven tooling but that's ok I just want to be able to select a feed rate.
    Thanks in advance,
    Mark.
    Jan 2013
    8
    I have the same problem how did you fix the G96 problem ?
  1. thc working or not?
    By empirecustoms in forum Mach Plasma / Laser
    Last Post: 12-21-2008, 11:15 PM
  2. What are you working on?
    By stevehuckss396 in forum I.C. Engines
    Last Post: 12-05-2008, 10:00 PM
  3. Don't know what I need to get this working, need help!
    By leirpytt in forum CNC Machine Related Electronics
    Last Post: 04-13-2008, 08:41 PM
  4. THC 300 not working?
    By Redline in forum Waterjet General Topics
    Last Post: 12-31-2006, 03:40 AM
  5. She was working
    By utengineer04 in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2005, 03:39 AM
