585,975 active members*
4,459 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Require DXF/DWG for 35 tooth sprocket.
    Jul 2003
    1220
    Hi, I need a drawing of one tooth for a 35 tooth sprocket to suit a 428 roller chain.
    I have the specifications from the Machinery Hand Book but will need to do some trig if drawing not available. Thanks.
    Mar 2004
    1543
    Jul 2003
    1220
    Thanks Karl
    That's much simpler than what the specifications call for, but I'm sure that's all I really need.
    Cheers.
    Sep 2008
    117
    Jul 2003
    1220
    Gene, Thanks for the site link, that makes things a lot easier. Cheers.
  1. Saburr-tooth burrs
    By cncbcncb in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-26-2009, 01:13 PM
  2. Where to buy 24/32 TPI straight-tooth set 131-1/2" Blade? + Q on wavy tooth sets
    By mcm375 in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2008, 04:28 AM
  3. Hardinge HLV-H Lathe, change gears, 127 tooth
    By leeputman in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2008, 02:29 PM
  4. can I get a 13 tooth timing pulley
    By unterhaus in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2006, 05:11 PM
  5. Cutting A Ten Tooth Spline On Vmc With 4th Axis
    By rrrrrgh in forum G-Code Programing
    Last Post: 08-19-2005, 10:33 PM
