585,932 active members*
3,853 visitors online*
Results 1 to 9 of 9
    Mar 2004
    1542
    computer control machine pot
    My plasma cutter has a pot to adjust the power level.
    I'd like control this pot through the CNC control. The CNC control can ouput an analog voltage signal -10 to 10 V. Or, it can turn on outputs. Five outputs can be used to provide 32 levels (2 to the fifth).
    i have no experience with electronic device design. What sort of device would fill this need?
    Karl
    Feb 2007
    4553
    Post pot driven control board
    Karl,
    CNC4PC makes a pot driven control board that would do what you want.
    http://www.cnc4pc.com/Store/osc/prod...roducts_id=179
    Give Arturo a call:
    Arturo E. Duncan
    1337 SW Sultan Dr.
    Port Saint Lucie, FL 34953
    Phone:561-208-6664
    Fax: 772-905-4387
    email: [email protected]
    Hope this helps,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    24221
    There may be a simpler approach, pot inputs can usually be substituted for a varying voltage between the common terminal and the pot slider input, you would have to check the voltage across the outer ends of the pot to find the max voltage seen at the slider input.
    There is a possibility to use an analogue input direct, or if the voltage required is larger than the analogue signal available, or it is not feasible to use a non-isolated approach, then maybe a OPTO IC such as H11F1 could be put to use.
    This OPTO accepts a varying voltage and the output simulates a varying resistance depending on voltage in.
    The input to the Opto may load the analogue signal up so a unity gain op amp may have to be used together with the H11F1.
    Al.
    Albert E.
    Feb 2007
    4553
    Question
    Al,
    Would a MAX5450 digital pot work?
    http://datasheets.maxim-ic.com/en/ds...50-MAX5455.pdf
    Jeff...
    24221
    I would think in this application it would be tricky, it is more suitable for processor or discrete logic control as it requires a known pulse train to control the wiper level.
    It also has no isolation if that is what is needed.
    Interesting chip though.
    Al.
    Albert E.
    Mar 2004
    1542
    Al.
    here's the data sheet.
    http://www.fairchildsemi.com/ds/H1%2FH11F1M.pdf
    Looks to do exactly what I'm after. I'm using a galil card for the signal voltage. Galil calls these analog inputs but the host control has a way to set these as analog outputs. Don't know how its done, not seeing anything in the galil manuals. Anyway, do i need a unity gain op amp? More importantly what is this device and exactly how would i wire it?
    Karl
    Mar 2004
    1542
    Quote Originally Posted by jalessi View Post
    Karl,
    Jeff...
    Thanks for the info. I'll go this route if i can't figure Al's simpler approach out.
    Karl
    24221
    I am away for the weekend, I will be back Tuesday.
    Did you check the voltage on the pot and does the unit show details of the pot input?
    Al.
    Albert E.
    Mar 2004
    1542
    Al.
    There's no rush on this. its got 24 volt to a 2Kohm pot.
    Karl
  1. Need computer to machine help
    By Larry Myers in forum Sharp CNC
    Last Post: 09-11-2019, 09:04 AM
  2. Computer to Control Comunication problem
    By JAnderson in forum Okuma
    Last Post: 05-21-2009, 07:55 PM
  3. Computer to machine help needed
    By Larry Myers in forum Controller & Computer Solutions
    Last Post: 08-21-2008, 05:37 PM
  4. Howto control Vexta UDX5114 via computer??
    By happytriger2000 in forum Stepper Motors / Drives
    Last Post: 04-19-2008, 11:13 AM
  5. VF-4 Control computer repeating characters
    By Drkk in forum Haas Mills
    Last Post: 11-02-2005, 05:32 PM
