585,763 active members*
4,202 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma cadet mate 4020 -OSP700M 1999
    May 2009
    8
    anyone has same model?
    my technician believes that this machine uses different code for Z-axis legth off set than G43 and G44.
    if it is different, anyone know what that is?
    Dec 2008
    3109
    Hi Taehk,
    All Okuma's use G56 to take up the length offset
    Fanuc's use G43
    usage example
    each offset # has 2 parts
    H= length, can be from gauge point, or from referencing tool
    D=tool radius which depends on programming.
    Code:
    G0 A--B---C---
    G0 X--- Y---
    S1000 M3
    G56 H11 Z1.0   ( forces rapid to Z1.0 using value stored in tool offset H11 )
    M8
    May 2009
    8
    Thank you sooo much!!!
    Because of your help, I can finally run my business!
  1. OKUMA Cadet-Mate V4020 question
    By kyrbe in forum Okuma
    Last Post: 04-17-2008, 06:42 AM
  2. Okuma OSP700M
    By marty kincaid in forum Okuma
    Last Post: 01-05-2008, 01:16 AM
  3. Okuma Cadet-Mate RS232/Serial port use?
    By brujo in forum Okuma
    Last Post: 06-21-2007, 01:35 PM
  4. 1999 Okuma cadet mate
    By NCcustom in forum DNC Problems and Solutions
    Last Post: 03-23-2007, 12:43 AM
