586,000 active members*
5,151 visitors online*
    Dec 2008
    36
    Unhappy 12" x 5.5" x 6" work area.. right?
    Obviously i dont have one yet but Im designing parts to be milled on a Deepgroove Taig. Those are the specs its listed with so I'd imagine i should be able to plop a piece of aluminum stock on that table in those dimensions and start working right?
    Im gunna throw a 12" x 5.5" x 6" block of aluminum on the machine and wont have clearance issues with the bits or whatnot? Sorry if this is a stupid question.
    Jun 2008
    1082
    It's not a stupid question at all, it's astute. The bed of the extended bed Taig can move 12" by 5.5" and the Z has at least 6" of travel. Problem is, larger stock will hit the Z ways and screw which affects the Y travel.
    Unmodified you should be able to cut a 12 x 3-5/8 x 6" block. But you'll probably be limited to the depth that you can cut into the block (I estimate you could go a little more than 2.5" in). If you need to cut to the bottom of the block the largest block you could start with would probably be roughly 12 x 3-5/8 x 4-3/8".
    Here's some threads where the travel distances are discussed some more...
    http://www.cnczone.com/forums/showthread.php?t=77518
    http://www.cnczone.com/forums/showthread.php?t=77319
    http://www.cnczone.com/forums/showthread.php?t=75869
    As I said, those are the dimensions that the Taig can do unmodified, there are ways to extend the travels in all three directions.
    Dec 2008
    36
    Awesome. I really appreciate you helpin me out with that luckily i havent been working on anything that will be effected by the differences in dimensions. Thankyou!
    :banana::banana:
    Nov 2008
    522
    The X-axis can actually extend further than advertised, it means the slides will only be half occupied as the table leaves it though. But around 14" before the leadscrew actually leaves the leadnut, IIRC. The Y and Z have hard limits on both sides though.
    The Z... OK say you have a 3" piece of stock and want to go all the way into it. You need a 3" long bit. So the Z-headstock needs to be 6" above the table. Actually there IS a fix there, the spindle mount and motor can be mounted like 2" or more higher in about 5-10 minutes. However, then you switch to a normal-sized bit like 1/2" long on thin work and find the axis gets to the bottom of the screw 1.5" before the bit reaches the work. So you'd have to change this out and it's not really quick to change repeatedly.
    But... technically, with the headstock on the top of its fixed dovetail and a small 1/2" long bit, I might be able to fit a 7.5" deep piece of work under it even though there's only 6" of travel. But I can only go 1/2" deep with that bit and have almost zero headroom to clear the work. In fact I can't even drop the bit out to change it with the work underneath it.
    Jan 2020
    Windows provide the area for working we can say that they are like playground we can work on it according to our mood. For this oxbridge essays reviews this will help you to understand the working purpose of windows.
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. Milling - Need 90" X 24"+ X 1" in alum - in NW area
    By ChinookR&D in forum Employment Opportunity
    Last Post: 04-15-2009, 12:46 AM
  3. BattleAxe "aka" Ball and Chain "aka" the wife.
    By ZipSnipe in forum Community Club House
    Last Post: 05-18-2008, 03:53 PM
  4. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
