586,005 active members*
4,833 visitors online*
    Jan 2008
    90
    TEK10 red LED keeps flashing
    Hello,
    I'm busy retrofitting my Hardinge HXL lathe with servomotors and TEK10 drivers. The system is running on 80Vdc and 10A max. A few weeks ago I already had this system running and did some testing with it. After that I removed the complete system to change the setup and complete the wiring.
    Now this week I've tried to assemble the elektronics on the machine again
    but without any results. As soon as I power up the system the red LED starts flashing. I've checked everything and it all seems to be ok. I got the 5V enable signal, the 12V on upper and lowerboard and the 80Vdc motor power input. Does anyone overhere has a suggestion what this problem can be?
    Regards,
    Bart
    Apr 2007
    8
    Hello,
    The same happened to me, do you find out wat the problem was / is?
    regards,
    Dirk
    Jan 2008
    90
    Dirk,
    I couldn't find the problem myself so I contacted CNCTeknix and they asked me to send the driver back for a check. There was a problem somewhere in the circuit and they fixed it without any costs! Good service!
    Bart
  1. Tek10 Servo Drives On Special
    By Kookaburra in forum News Announcements
    Last Post: 09-27-2010, 05:36 AM
  2. Mycenter 1 Alarm Flashing
    By Pmp Audio in forum Fanuc
    Last Post: 02-24-2009, 04:12 AM
  3. TEK10 problem!
    By Patrick_v_M in forum Servo Motors / Drives
    Last Post: 04-18-2008, 03:22 AM
  4. Flashing bit
    By mr_electrician in forum Fanuc
    Last Post: 02-15-2008, 08:19 PM
  5. Teknix Tek10 VS Gecko G320
    By gripen in forum CNC Machine Related Electronics
    Last Post: 06-06-2007, 05:01 AM
