585,748 active members*
3,735 visitors online*
IndustryArena Forum > CAM Software > Mastercam > mastercam postprocessor for weeke
Results 1 to 8 of 8
    Nov 2008
    hello
    i need a mastercam postrprocessor for weeke because now i work with homag woodwop 5 for generate the .nc code but it don´t have much posibilities for 3d machining
    sorry for my bad english
    Mar 2005
    461
    There are lots of post processors available for Mastercam directly from CNC Software but you need to go through your Mastercam reseller to get them.
    Give the Mastercam reseller a call. I am sure they can help you.
    Jul 2009
    Hallo,
    The most mastercam dealer sells postprocessores for homag and Weeke machines. The big problem: They posts only universalmakros (G-Codes). If you get more, you need a professional postprocessor. I did develope together with our mastercam-dealer a really good postprocessor: All WoodWop-Makros are possible. If you have any interest send me a message. Also I can send you are example as mpr-file.
    Greetings from Germany.
    Jan 2009
    32
    Re: mastercam postprocessor for weeke
    Do you have a postprocessor for HOMAG BAZ 10 program woodwop 2.5 Homatic 2000
    greeting
    Oct 2006
    32
    Zorane,
    pokušao sam ti poslati odgovor na PP ali iz nekog razloga nije moguće.
    Pozdrav,
    S.M.
    Jan 2009
    32
    aluplastvz et yahoo.com
    pozdrav zoran
    Apr 2008
    20
    Hi there
    our floppy disk was broken on our weeke BP15 homatic 2000.
    Does anyone have experience with USB-floppy emulator installing on weeke BP15 homatic 2000. I bought Gotek emulator and have problems with installing. i install it on my desktop PC like 1.44MB 3.5" and after that I try install it on weeke machine without success.
    on machine display i can read OS-9/68KB floppy Disk type is 5" floppy (but in reality i see 3.5")
    Sectors/tracks = 32
    min. sect allocation = 8
    i have picture of this screen.
    can anyone advice?
    thanks
    Nov 2010
    Quote Originally Posted by 3d-holzdesign View Post
    Hallo,
    Can You share Your post? What is Your MasterCam dealer?
    I have few weeke and go for MasterCam now.
  1. Replies: 3
    Last Post: 03-28-2024, 09:08 PM
  2. Weeke BP 120 and Weeke 2000-IPC Win98 PC Crashed
    By glenn_wood in forum CNC Machining Centers
    Last Post: 01-04-2020, 10:34 PM
  3. Weeke Mastercam post processor
    By richardanderson in forum Post Processors
    Last Post: 02-17-2010, 08:15 PM
  4. mastercam x2 postprocessor
    By bizdad in forum Mastercam
    Last Post: 10-12-2008, 11:05 AM
