585,996 active members*
4,502 visitors online*
Results 1 to 6 of 6
    Oct 2008
    45
    Mazatrol 640M/ EIA program
    Do I need a H nest to the G43 so it know what Tool offset we are in use?
    Here is what I get when I post..
    O0001(D-63636)
    (DATE - 07-01-09)
    (TIME - 12:11 PM)
    ( T5 | 1/2 2FLT SCEM | H5 | XY STOCK TO LEAVE - .3 | Z STOCK TO LEAVE - 0. )
    ( T14 | 1/2 BALL CUTTER | H14 )
    G20
    G0 G17 G40 G49 G61.1 G80 G90
    ( ROUGH OUT .300 LEFT ON FACE )
    T5 M6
    G0 G90 X-.4121 Y3.86 S12000 M3
    G43 Z3.5 T14
    G1 Z2.75 F100.
    X25.2771 F200.
    Z2.558
    X-.4121
    Y4.5308 Z1.5158
    X-.4121
    Y4.6665 Z1.38
    X25.2771
    G0 Z3.5
    M5
    G91 G28 Z0.
    M01
    ( FINISH FACE )
    T14 M6
    G0 G90 X-.4121 Y3.56 S12000 M3
    G43 Z3.5 T5
    G1 Z2.5 F100.
    X25.2771 F200.
    Z2.4508
    Y4.3812 Z1.0946
    X-.4121
    G0 Z3.5
    M5
    G91 G28 Z0.
    G28 X0. Y0.
    M30
    Mar 2005
    988
    It depends on your machine parameter settings and what style of offsetting you're using (Offset page or Tool Data page).
    It's just a part..... cutter still goes round and round....
    Oct 2008
    45
    Quote Originally Posted by psychomill View Post
    Yes But does it use a "H15" After G43 or does it know from the tool it self?
    Dec 2005
    10
    hello,
    as psycomill said, it's depend on your parameter setting. You can check it at User Parameter --> F parameter (EIA/ISO). F93 if I'm not wrong.
    if you use tool offset, you need to put H there.
    If you use tool length of tool data, you no need to put H there. It will follow tool data value.
    Please read operation manual book, Setting tool data for EIA/ISO section for detail explanation.
    Oct 2008
    45
    Thanks I will take a look.
    Inky
    Will it hurt to have the H12 for a T12 ?
    Oct 2008
    45
    Final
    Ok now i got it thanks to everyones help.
    Full eia no mazatrol at all THANKS
    Inky
  1. Mazatrol Program into a G Code Program
    By fuzzman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-25-2012, 04:27 PM
  2. Mazatrol 640M/ Matrix Post
    By BryCAM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-27-2012, 07:30 PM
  3. Mazak Mazatrol Fusion 640m- FH6000 - Alarm 391
    By riddmj in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-23-2011, 07:42 AM
  4. Mazatrol Sub Program
    By jhersh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-03-2008, 11:09 AM
  5. Mazatrol 640M
    By hense in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-12-2008, 06:56 AM
