585,942 active members*
3,345 visitors online*
    Mar 2009
    1114
    Im LOSING steps?!
    Hey all, i'm calibrating my steps per on my mill and having a very hard time with my y axis. It's on ballscrews and linear rails and very smooth so binding isn't the issue. When i try to and step to my gage block to touch with the indicator sometimes it will move a true .010 and other times the motor wines just ever so slightly and will on move a few thou. As you know this will make it near impossible to calibrate.I'm stumped. I did my x and z perfectly. I got them with in .0001 on each axis. But the Y is being a b***h.
    Any suggestions? I'm using mach3 by the way.
    PS I tried turning down the Acceleration but still the same result.
    Thanks.
    Jun 2008
    1082
    I'd probably mess with the acceleration some more. Although it's counter intuitive it's possible increasing the acceleration will help.
    Does the motor act the same way at any part of the table?
    - sorry, I know you already said binding isn't an issue, I just figured I'd ask this anyway in case it helps.
    Maybe something is wrong with that driver?
    Try hooking the Y to another driver - does the problem go away?
    and/or
    Hook the Y driver to another axis - does the problem appear on the other axis?
    Feb 2009
    Hi, You're saying that when you touch the Z axis with your finger, it drops a little, right?
    What kind of steppers are you using? It can be low torque problem I guess. If torque isn't the problem, maybe there's lacking (or missing ajustment)power, what kind of eletronics are you using?
    Anyway, this can be fixed with some springs
    (the springs ideia can be hard to accept at first, but they're very funcional and sometimes common as a compensation system helping lifting.)
    Mar 2009
    1114
    no the problem is the Y axis not the Z. Keling motors, Gecko G540, 48v PS nothing crazy
    Jun 2009
    33
    Hoss has some good videos on calibration. Check out hossmachine.info
  1. Losing steps?? How do I know??
    By JeLC in forum DIY CNC Router Table Machines
    Last Post: 09-09-2009, 12:26 PM
  2. Wincnc losing steps
    By cut more in forum WinCnc
    Last Post: 04-08-2009, 07:14 PM
  3. Help with CNC losing steps
    By Scramjet in forum DIY CNC Router Table Machines
    Last Post: 01-30-2008, 01:24 AM
  4. Losing steps - WHAT IS UP?!?
    By Sporqster in forum DIY CNC Router Table Machines
    Last Post: 04-27-2006, 03:50 PM
  5. Cause For Losing Steps?
    By FLUTE HEAD in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-14-2005, 01:54 PM
