585,974 active members*
4,229 visitors online*
IndustryArena Forum > CAM Software > OneCNC > OneCNC & Alibre (Part 2)
    Sep 2004
    239
    Thought the other thread was getting too long. So start anew.
    I took a fairly complex and large assembly file from Alibre. It is a model of a lower part of an engine (block, pistons, rods, etc.). The parts and the assembly were part of Alibre's tutorial. I exported it to a 214 STEP file and imported it into OneCNC.
    I am quite impressed. It loaded up without a hitch. I then took each individual and unique solid one at a time (block, one rod, one bracket, and one piston) and extracted the surfaces and re-merged it back into a solid. All of the solids re-merged except the Piston.
    There is some commonality with the surfaces in the piston that are similar to the other parts that I have modeled, tried to import and modify, and crashed also.
    Maybe someone (from OneCNC or Alibre) can pinpoint what those surfaces are that are causing the problem.
    Anyway, I will try and include the zip file of the OneCNC XFA file of this engine. It is nice to look at if not for any other reason. :banana:
    Performed some more work on the model. I took the Piston copied and pasted it into a new file. I extracted all the surfaces. Now, if I re-merge the surfaces a few at a time, in groups, and then re-merge all the groups, I am able to re-merge all the surfaces back into a solid.
    Once re-merged, I can then extract all the surfaces and re-merge them all in one command.
    Question for OneCNC (perhaps), does OneCNC fix mating edges of surfaces during the merge function? And if there are some slight miss alignments in some surface edges, it is just too much for OneCNC to fix all in one shot, and that is why it will re-merge pieces at a time instead?
    Chris
    Attached Files Attached Files
    Sep 2004
    239
    There was an interest from a CNCzone member to post this file in a different format.
    Attached is a ModelPress Publisher file that can be viewed by the free ModelPress Reader. You can download the reader from their website: http://www.modelpress.com/
    Chris
  1. Onecnc and Alibre
    By brtlatjgt in forum OneCNC
    Last Post: 02-16-2005, 02:04 AM
  2. Replies: 8
    Last Post: 08-24-2004, 05:05 AM
  3. OneCNC is a SolidWorks Solution Partner
    By OneCNC in forum OneCNC
    Last Post: 04-01-2003, 05:37 AM
  4. OneCNC is a SolidWorks Solution Partner
    By OneCNC in forum News Announcements
