585,585 active members*
4,072 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Motor Linearity on PK299-F4.5 (from OM) and KL34H295-43-8B (from Kelling) ??
Results 1 to 2 of 2
    Feb 2007
    17
    I'm trying to understand the motor linearity and what it does to the performace of a stepper motor. Does it has to do with the internal mechanical dimensions of a determined motor?
    I need couple of motors with 800-900 oz/in of holding torque and so far here are the options I have come up with:
    - PK299-F4.5a from Oriental Motors (8 lead). I have seen many threads mentioning this motor and it's impressive performance.
    http://catalog.orientalmotor.com/ite...=prod&filter=0
    - KL34H295-43-8B (8 lead) from Keling, these are chinese motors, but, apparently have impressed some important people (Mariss from Geckodrives) with it's performance.
    http://www.kelinginc.net/KL34H295-43-8B.pdf
    Any thoughts or comparisons very appreciated
    Francis
    Feb 2007
    17
    Gave a STFW to myself and here it is....
    STFW means: Search the fu#!%! web !!
    I found nice stuff about motor linearity, it's really worth the reading. It is an important characteristic of a motor when running it at very low speeds!
    It explains why big stepper motors resonate loudly at low speeds.
    http://sanyo-denki-online.com/library/accuracy.pdf
    http://www.mechmate.com/forums/archi...php/t-255.html
    Could anybody help with the 2 motors mentioned before and it's linearity characteristics?
    Thanks,
    Francis
  1. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  2. use satellite dish actuator motor as a stepper motor
    By ozni in forum Stepper Motors / Drives
    Last Post: 06-19-2010, 01:55 AM
  3. Problems with motor stalling due to motor/lead screw alignment
    By Bimmerkc1 in forum DIY CNC Router Table Machines
    Last Post: 01-25-2010, 01:12 AM
  4. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
  5. servos motor controled by stepper motor driver?
    By mike10 in forum Servo Motors / Drives
    Last Post: 01-04-2005, 12:05 AM
