585,978 active members*
4,232 visitors online*
Thread: Pin array
    Jul 2005
    107
    Pin array
    http://www.swiftnets.com/assets/imag...BASE-PLATE.gif
    I would like to try cutting something like that in mastercam. The facing, bolt pattern, etc. is pretty obvious, but how to have mastercam understand the diamond cut isn't so simple to me. What's the best way to have mastercam cut along a bunch of parallel, equidistant lines, up and down so both sides get climbed?
    Dec 2008
    3109
    To machine each diamond separately would not be really efficient,
    IMO- I would extend the geometry on the pins laying on the diagonals and extend these past the outer boundary of the "pin area"
    Rough & finish outer shape of pin area
    For roughing to half way- a pass down the gap centre
    For finishing to half way - 2D contour these new curves
    Repeat to get full depth
  1. L10 cut array command
    By RossMColquhoun in forum G-Code Programing
    Last Post: 03-05-2009, 01:59 AM
  2. Array with v20
    By DEW in forum BobCad-Cam
    Last Post: 11-21-2007, 12:50 AM
  3. 7 Amp X 5 Mosfet Array
    By scratch_6057 in forum Open Source Controller Boards
    Last Post: 01-28-2007, 03:24 AM
  4. LED array sequencer
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 11-21-2006, 06:31 PM
  5. Linear Array
    By hay171717 in forum G-Code Programing
    Last Post: 05-28-2004, 07:18 AM
