Thanks for any help in advance guys.....the dilemma I have is that I need to shift from the typical Mazatrol programming we normally use on this machine to the EIA-ISO format for a specific job. I use Feature-Cam and have generated my shapes and output NC code. First of all, FeatureCam comes with many post-processors so choosing the correct one may be my issue. I've had no issues sending EIA programs to the Mazak, they just won't fully run. The program below upon Cycle Start will change to the proper tool then just sits there. I just don't know what this machine needs. Are there parameter settings I need to change when shifting from Mazatrol to EIA? Also, is the Z axis the same direction in Mazatrol as it is in EIA/ G-code? Sorry to bombard you guys with all the questions but I'm beginning to exhaust my options. Here's the code I've sent to the Mazak.......
O1234
N02G50S1200
T0202M41
G97S1200M3
G0X-2.7Z0.1M8
G96S1200
G04U2.
G95G1Z-0.0002F0.015
X-2.5
G3X-1.4Z-0.2746R2.7479
X0.Z-0.4R2.073
G1X0.1737Z-0.3504
G0X-2.7Z0.1312
X-2.557
G96S1600M42
Z0.2464
Z0.1151
Z0.1312
M5
X5.6974Z-8.9707M9
T0200
M01
M30
Thank you!!!!!!!!!!
