Check it out.
http://www.visualmillforsolidworks.com/
Check it out.
www.integratedmechanical.ca
Darebee, your using Visual are you not? Have you heard anything in regards to their 5 axis and how well it's working?
Adding it into SolidWorks is a good move.. I've been doing pricing w/ SolidCAM recently but I'm glad I waited.. now I've got another option to test..
My primary concern w/ 5 axis is that it is able to do the tool offsets in the program vs doing them in the Control software..
Thanks for the heads up..
J
JerryFlyGuy
The more I know... the more I realize I don't
Double
Hi Jerry
I am sorry I know nothing about the 5 axis.
I only use 4.
FWIW I do not use cutter comp in my control. I run the code as generated and set stock values to +/- as needed.
I think the 5 axis is a 3+2 system. I don't see why it couldn't be a 4+1 (but I don't make software so I don't understand programming intricacies)
I should have added.
Give Anita a call at MecSoft.
They are very nice, will do online demos on your parts and you will get NO pushy sales calls (they better not make a liar out of me :stickpoke)
They work directly with us users to resolve issues.
Tell Anita Derek from Integrated Mechanical sent you and that she better treat you right.
I believe there is a reseller in TO now, but I deal direct with MecSoft and have no intention of changing.
Thanks Derek, I may just do that First I'll probably tag along on that roll-out on the 22nd. Then if things look good I'll get in touch w/ them.. I'm getting closer to doing a deal as I've had several projects of late that would have benefited greatly from multi axis [and less setups]..
Thanks!
J
JerryFlyGuy
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
