585,925 active members*
3,557 visitors online*
Results 1 to 12 of 12
    Dec 2004
    132
    Haas mini mill
    I am thinking about getting a mini mill. I plan on making some sprockets for myself production wise. I know I could sell them.
    Does anybody have this machine? How do you like it?
    927
    Pyro,
    We have one of them on the floor..like it a lot..been a good machine..had it since Aug. 2000..
    No issues what so ever..though it is not a VF3 by any means..still we replaced a cnc knee mill with the Mini..and it was a good decision..
    HTH
    Dec 2004
    132
    Quote Originally Posted by wms
    Pyro,
    HTH
    What you mean not a vf3? Can it not do the same things? Or is it not as fast. If it isn't as fast I can deal with that cause I am used to a bridgeport now.
    927
    Well By that I mean a Mini Mill is Not a VF3..like a Chevy S10 Is not a Chevy 1Ton with a Duramax diesel..Apples and Oranges.
    Yes a Mini can do what a VF3 can...just not as big of parts or as many of them at one time. It is just the difference between a 40 inch machine that weights 14,000 lbs and one that is a 16 inch machine that weights 3,400 lbs.
    Dec 2004
    132
    I see what you mean I wouldn't even be able to afford a vf3 what are they like 50k I could do 26 but not double that. I am only starting out.
    So it is a good machine ot start out with?
    927
    Yes a Mini Mill is a good machine to start out with.. So is a VF1...
    But you will find that a VF1 will go for about $42,000 new with no options..and VF3 is more like $85,000..so a Mini Mill will be around $30,000 base price new...Of course there are a few used machines around..
    Dec 2004
    132
    30k is more in my range for now hah
    Dec 2004
    132
    whoa now. Did I say mini mill. I think I meant tool room mill. What is the difference. besides the 14" more in the x axis?
    Dec 2004
    132
    really they look like the same machines. Same motor it apperas like just the mini comes with a took changer vs the tool room doesn't. hmm
    Apr 2003
    1873
    Essentially they are the same machine, but the Tool Room Mill is derated to 200IPM for safety because it is a open machine (Thank you OSHA) where the Mini is I believe 600IPM rapids. , the spindle speed is also higher on the Mini at 6000rpm, the TM1 4000rpm.
    If you decide on the TM1 because of pricing do definitely get the auto tool changer.
    Dec 2004
    132
    Quote Originally Posted by Ken_Shea
    yea I definilty wnat the auto tool changer hah I hate changing tools on the knee mill
    May 2007
    I am selling mine...
    Quote Originally Posted by pyroracing85 View Post
    Pyro, I am thinking of selling mine. I bought it for making parts for a certian job that only had small parts. It was my first machine. I love it, but have not been able to use it much.
    It is a 2006.
    I got the 16MB, cover, high flow coolant pump, rigid tapping, and programmable coolant.
    I love the high flow pump and the Pcool options. The high flow allows me to run two manual nozzles and the pcool which moves to the right hieght for each tool or tap. I can let it run knowing that the coolant will never be off the tool...
    --Cory
  1. What size steppers for Grizzly mini mill?
    By Mini Miller in forum Benchtop Machines
    Last Post: 07-18-2005, 05:45 AM
  2. Version 1 Mini Mill project log
    By mannster in forum Vertical Mill, Lathe Project Log
    Last Post: 05-19-2005, 03:56 AM
  3. Capabilities of mini mill @ $2500
    By jl123 in forum Benchtop Machines
    Last Post: 05-14-2005, 03:59 PM
  4. First Impressions for CNC mini mill conversion
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2004, 03:37 AM
  5. New to Mill and CNC - Can you mix a Mini and Micro Mill
    By Sherpa in forum Benchtop Machines
    Last Post: 09-09-2004, 03:36 PM
