585,981 active members*
4,307 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Manual tool comp on partial radius (Lathe)
    Jul 2009
    33
    I've been trying to figure out on my own how to manually calculate the tool nose compensation on a partial radius for a while now and i just can't seem to get it. However, I can get it right when i use the formula for tool comp on a straight line. So basically my question is: Is the formula for figuring out tool nose radius compensation the same for angles as well as for radii?
    Here are the formulas i am using:
    z axis comp= nose radius-(nose radius x tan(angle [divided by] 2))
    x axis comp= 2 x [nose radius-(nose radius x tan(45- (angle [divided by] 2))]
    Dec 2006
    19
    from the theoretical sharp corner trig out start finish points of the arc + tnr for .1 arc and .0312 tnr .1312 arc then program r value .1312 hope this helps.
  1. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  2. Manual tool comp on partial radius (Lathe)
    By cSpampinato in forum Mechanical Calculations/Engineering Design
    Last Post: 07-16-2009, 02:02 AM
  3. Manual tool comp on partial radius (Lathe)
    By cSpampinato in forum MetalWork Discussion
    Last Post: 07-13-2009, 01:53 PM
  4. Help with tool nose radius comp
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-09-2008, 02:25 PM
  5. Tool radius comp
    By cijunet in forum Mastercam
    Last Post: 12-20-2007, 10:27 PM
