585,996 active members*
4,572 visitors online*
    Sep 2005
    371
    4th Axis (Rotary) moves relative not absolute
    I just set up my 4th axis and it's moving fine in both directions. If I'm setting at 0º tell it to move A20, it will move to 20º. That's all fine and dandy but if I want it to move to 40º, if I input a code of A40, the rotary table will add, i.e. move it by 40º winding up at 60º.
    I must have some simple setting not set correctly.
    I don't want to have to remember where the table is and do the math. I simply want it to land at the degrees I tell it to.
    Mine goes where I tell it. Are you in Incremental mode (G91)? Do you have any boxes checked under "rotational" in General Config?
    Sep 2005
    371
    Nevermind. I rebooted and it's working fine now. Hate when that happens...
    Thanks anyway.
    Oh, I do have the "Rotational Soft Limits" checked but nothing else.
  1. Zero X axis absolute encoders
    By Cov Kid in forum Fanuc
    Last Post: 07-29-2009, 05:28 AM
  2. G54 X-axis moves??
    By Florida Ted in forum Haas Mills
    Last Post: 03-15-2009, 05:09 AM
  3. Absolute and relative
    By jorgehrr in forum CNC Machining Centers
    Last Post: 10-10-2007, 09:42 PM
  4. No A axis moves ? ( in post )
    By Scott_M in forum FeatureCAM CAD/CAM
    Last Post: 08-09-2007, 02:37 PM
  5. Converting G2 & G3 Moves to Rotary Axis?
    By skibbey in forum G-Code Programing
    Last Post: 04-03-2007, 01:40 PM
