Originally Posted by
jduke
So I am supposed to spray a lubricant on the table where I am going to be trying to clamp things, and keep them from moving?
with woodworking, it makes sense to use a lubricant, because your not clamping anything to the cast iron, its better if its slick.
But It seems rather odd to me, to put a great lubricant on the table of a mill, and then try to clamp a workpiece to it, and expect it not to move after I just lathered it up in Lube.
Duke
I may end up using the WD-40 until I can find a product that I can expect to keep the rust away when I am going to be away from my equipment for a week or two at a time. My experience, has been that WD-40 drys out when its left for a while.
Where around Houston would I be likely to find LPS products?
