What type bits should I be using for routing out Printed Circuit Boards? Currently I'm using an Engraving Spindle which uses 1/8" cutters. I've tried 0.005" and 0.010" bits and both have broken while cutting boards. These types of cutters have an angle to them (not like end mills) so setting the depth and width can also be difficult. I guess they are really only designed for cutting plastic, but I though that being carbide would be good enough for cutting copper/fiberglass.
What are you using?
CP
