585,982 active members*
4,385 visitors online*
    Jul 2007
    13
    Retention knobs
    I just recieved my sharp 2412. I'm trying to find out if the manual has a misprint on the retention knob print, as it seems to be an uncommon size. The dia. between the flange and the knob on my print says it's 9.8mm or ~.386". But the common size is .490". Can someone with a 2412 confirm the retention knob size.
    Thanks for the help,
    Michael
    2932
    Everything I have on the 2412 specifies a Valenite PT-475 pullstud. See attached .jpg.
    Aug 2009
    9
    0.392 is actually fairly common. It's an adaptation of a BT40 pull stud but with the 5/8-11 thread to fit CAT40s.
    However, I think you may be right that the 2412 uses the .490 size. What did Sharp say about this?
    Apr 2007
    32
    I have been using the .490 for 2 years now with no problems at all.
    Jul 2007
    13
    It is the .490. Thanks everyone.
  1. Ever used these retention knobs?
    By rawen2 in forum Haas Mills
    Last Post: 09-19-2008, 04:41 PM
  2. Retention Knobs for Mitsui Seiki VR 3A
    By barchdesigns in forum CNC Tooling
    Last Post: 07-07-2008, 05:57 PM
  3. RETENTION KNOBS
    By Jfrahm in forum CNC Tooling
    Last Post: 05-31-2008, 02:07 PM
  4. Control knobs for musical instruments
    By munich2007 in forum Moldmaking
    Last Post: 11-29-2007, 03:20 AM
  5. Shift knobs
    By hot knobs in forum Trade Shows / Webinars / Other Events
    Last Post: 08-12-2007, 01:34 PM
