584,842 active members*
4,388 visitors online*
Results 1 to 7 of 7
    Mar 2006
    107
    Turret servo amplifier failure
    Machine is Lathe ROMI G15SM, 2001. y.
    CNC is Fanuc 18i-TA
    There are two alarms:
    1005 TURRET SERVO AMPLIFIER FAILURE
    2024 TURRET PULSE CODER BATTERY LOW
    I do not know if these two alarms have something in common.
    There is SERVO AMPLIFIER UNIT beta SERIES which I beleave is for turret rotation.
    A06B-6093-H152
    On it's display there are flashing some codes:
    U ; 2 ; 1 ; 11 and so on in circle
    When I try to change tool (to rotate turret) first I hear some noise (breaking pin goes out?) and than nothing.
    You can see turret type on pic.
    Please if someone has got any experience with simmilar problem or maybe has got manual for this servo amplifier, please help me.
    Sorry for bad english
    Nov 2006
    175
    The absolute pulsecoder battery is low or disconnected. Connect new batteries and see manufacturers documentation how to set reference for this drive. You can see more on SYSTEM/PMM screen.
    Attached Thumbnails Attached Thumbnails Beta_I_0 Link_ALM1.jpg   Beta_I_0 Link_ALM2.jpg   Beta_I_0 Link_ALM3.jpg
    Mar 2006
    107
    OK, I changed the battery.
    BUT, now there are two new problems.
    1. It gives me wrong tool, not the one I have commanded.
    In the manufacturer manual there is no word about turret referencing or anything similar.
    2. After tool is changed (completely, just wrong tool N.) by MDI command Txxxx, the T command is not completed and I get "Cycle not completed".
    Could reason for that be just the wrong tool number?
    Does machine know that changed tool is wrong?
    At SYSTEM/PMM screen I just see whole bunch of 0 and 1's, but I don't know which parameter is for what
    Mar 2006
    107
    Problem solved, I got from machine builder the procedure for turret zero point.
    The catch is parameter #11 bits 0 and 7.
    May 2006
    64
    I setup Tapping Machine Kira, the same with your case
    A06B-6093-H152 is IO link beta servo, you need reload all parameter before replace new battery, if you don't have A06B-6093-H152 manual i will send you for more clearly.
    My email : [email protected]
    Jun 2010
    A06B-6093-H152 SERVO AMP. Don't have fault code list. Getting r (what looks like a little r) on the 7segment display. Anyone seen this before?
    Sep 2021
    42
    Re: Turret servo amplifier failure
    a xin ???c manual ch?a a
  1. EMCO MAXXTURN 65 alarm 2079 TURRET referencing failure
    By samirabaza in forum EMCO Lathe
    Last Post: 04-07-2014, 04:15 PM
  2. ATC TURRET FAILURE and ALARM
    By scadvice in forum Fadal
    Last Post: 03-29-2011, 05:36 AM
  3. Puma 240MB - Turret servo amplifier
    By Alex_Kozletsov in forum Daewoo/Doosan
    Last Post: 07-08-2009, 01:08 PM
  4. Servo drive / Servo Amplifier
    By Ken_Shea in forum Servo Motors / Drives
    Last Post: 07-10-2007, 11:12 PM
  5. Tool Turret Index Failure
    By hatchmar in forum DNC Problems and Solutions
    Last Post: 06-10-2005, 12:36 AM
