585,886 active members*
6,214 visitors online*
Thread: Lathe turret
Results 1 to 1 of 1
    Jul 2004
    442
    Lathe turret
    I am converting a 14-40 Vectrax lathe to CNC. It's not a heavy duty machine but larger than I really need, so it will be fine.
    I saw, and couldn't resist a turret unit on 'bay; below.
    So next I bought the accessory kit; also below. The turret has 5/8" holes.
    The turret came from a 10" Logan, so I'll have to make an adapter plate to raise and center it.
    I have a fair number of drills larger than 1/2" with stepped down shanks and they will be fine to use with the turret, but I also have a very complete set of good quality drills, up to 1 1/4" including some metric sizes, that have Morse taper shanks, mostly MT3.
    So here are my questions:
    In making the adapter plate, how can I achieve the most exact height to match the lathe spindle height. The other factors, parallel, side to side, I can make adjustable so no problem there, but how best to get the exact height?
    The other question is how should I modify to be able to use the MT3 taper drills? Some of my ideas are; to make a external adapter 5/8 to MT3 but it seems that would be a lot of overhang; or, to mount the turret head in my other CNC lathe and machine out one of the holes to MT3, but if I screw it up, I've ruined the head. And then I'd need to make a slot for a tapered pin for release. I also don't know if there is enough depth there for the MT3 taper.
    So I'm looking for ideas.
    Thanks in advance
    Ozzie
  1. Converting my Engine Lathe to an 8-Station Turret Lathe!
    By widgitmaster in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2018, 04:56 PM
  2. Trouble with lathe turret
    By Joe Miranda in forum Milltronics
    Last Post: 08-11-2008, 08:32 PM
  3. DIY Lathe Turret
    By PEU in forum Vertical Mill, Lathe Project Log
    Last Post: 08-07-2008, 01:33 AM
  4. Turret for a cnc lathe
    By mtechserv in forum Uncategorised MetalWorking Machines
    Last Post: 02-18-2008, 12:01 AM
  5. LMS Lathe Turret
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 11-29-2005, 04:41 AM
