Hi guys,
I think Photograv outputs a 1 bit .tiff file for the .bmp picture.
(You have read the instruction manual, haven't you ???) I did but it was a long time ago.
On my laser, using Photograv with Corel Draw, I set the resolution to 300 pixel per inch (ppi) for the picture but I engrave at 280 ppi on the laser.
Photograv say not to do this but if I engrave at the same resolution I get a picture that looks like I am looking at it through a fly wire screen. No amount of "noise" can break up this pattern. It's not noticeable in the picture until I actually engrave the file.
I have used "diffusion dithering" but it still exhibits the same darn checkered pattern
Very frustrating indeed and I have wasted a lot of material finding this out so now I set the engraving at 280 ppi (or dots per inch, dpi) on the laser.
You should do most of your processing in Corel, Photoshop etc before you send to Photograv adding text, enhancements/embellishments etc and also the size you will be engraving at.
Preparation is the key, like painting.
Check to make sure all your pulley/belts are tight and there is no slop in your system as this will cause problems also.
Try this out then get back to us.
What are you doing with your machine? and what software are you using?
Try to let us know everything you have so we can all make an informed decision on what may or may not be wrong.
A lot of people I talk to say that laser engraving is dead simple and all you have to do is put the picture in and the laser engraves it. Dead easy!!!
Those people don't have a laser engraver! :-)
Rich.
I am not completely useless.......I can always serve as a BAD example.
