Is there any disadvantages in accuracy etc on using a BIG nema 42 3200 oz compare to nema 34 1600 oz? or the disadvantage only the bigger one is more expensive?
first go see that site
http://www.geckodrive.com/upload/Step_motor_basics.pdf
second:you have to be aware that the bigger is the motor the more
inductance it will have;that increased inductance will meen that you will have
to operate those motors at a higher voltage to get good performance;
third: the torque versus speed curve of big motors usually falls very fast.
Andy
You may want to consider servo's if you need that much torque.
Amplexus
Depends on the application.
